Figured this would be the place to post this.
Front end has no factory adjustment, loosened the subframe and slid it over but there wasn't much to be gained. The added caster at the RF, did help make the car neutral.
Rear has a dummy axle. The last person that had done an alignment had stripped a bolt out, at the RR tire and just placed a metal shim in one corner to adjust the alignment. Just that it was the wrong type of shim and the wrong corner.
This is an alignment that i did while at work, just wanted to post to hear any comments or constructive criticism.
FYI: Car had one different brand, newer tire on it (RR corner).
