This is just all [censored].
I used to ride a motorcycle and the same question was asked: What is so special about MC oil as opposed to standard oil for cars???? Early on I actually bought a semi-synth MC oil for $10/qt!?!?!? (before BITOG of course
Well no one could really give a proper answer besides the single difference being moly that can cause MC clutch to slip (MCs use the same engine oil for wet clutch). Thus the *main* difference was higher prices based on MC labeling, claiming that oil is specially domulated for bikes.
I learned that the plain HD oil used for diesel engine works just fine in motorcycles and saved a bunch of money by never buying MC specific oil ever agan.
So this is the same thinkg. Kawi dealer will make some fake claim about some supposedly "important" difference or won't even try to explain why cheaper car oils don't work for lawnmowers. Most of the time this specialty oils are very similar or have minor differences like straight wt, but command a much higher price.
I think you are looking at this backwards. Oil choice comes at the end. Start with looknig at you duty cycle.
For instance,
I have a Kohler Commander 16hp, doing about 2hr/mowing runs at moderate temps (max 30C) and moderate load, plus many short runs when hauling wood and other stuff. It does about 50 hr/season, has a filter (changed every other season) - per schedule.
So I would call this a moderate duty cycle = multi-vis
Since my duty cycle is moderate I will use a plain car multi-vis oil. No need for straight 30. I try to use a 5W30 sprint/fall and 15W40 during summer. These are both in the manual.
Now consider a contractor in TX:
ambient 40C, longer 3-4hr mowing runs, etc. This would be a heavy duty cycle so straight 30 or even straight 40 would be a better choice.
When wour vendor or manual recommends ONLY a single or 2 grades then they are simply being lazy. The fact is that for different duty cycles, different use patterns there are different oil types that best fit them. There is a big difference between a contractor pushing a machine hard every day and an average Joe doing occasional mowing at low load.
So forget about oil and consider your needs 1st. Then match oil type to your needs. For some it is straight 30. For me in Canada straight 30 is too much (colder climate).
