Originally Posted By: timeau
Originally Posted By: lancerplayer
For the last 2 OCIs, my 2009 Honda Accord EX-L 3.5L V6 has used about 1 quart in 3k miles.
Is this excessive?
Yes.
Should I be concerned?
I could say "no, this is normal" just to repeat what other are saying. Many of us would do ridiculous things just to be "as all other". But I'll say: yes, this is a problem. Just
THINK what could be the reason of oil consumption. Think, and everything will be much clearer:
Reasons:
0. Leaking oil pan gasket or nut.
1. Clogged PCV valve. Is it normal to have it clogged?
2. Worn valve seals. Is it normal? But I think that this is not your case.
3. Clogged oil drainage holes in the pistons.
4. Clogged piston rings.
I would check PCV first. But I am 99% sure that it is more or less fine. The reason of your troubles is in deposits on pistons.
There are a number of solutions. All of them are against "local rules" since people in case of problems prefer to change the thickness and oil brand. This sounds like to treat cancer by eating chocolate yougurt twice a day, but let it be. So my personal proposals are:
1. After a quart of oil is consumed add a quart of transmission fluid. Drive for about 500-1000 miles.
2. Add deposit control staff into your oil. My favorite is this
VitaFlush, but regular
STP could work too. I just did not try STP myself. Also I consider MMO as useless staff.
3. Change oil and forget about Pennzoil Platinum. Use Pennzoil Yellow, Mobil Super, Castrol GTX. These Group II oils have better additives holding.
4. Change oil each 5k miles. This is cheap, don't play in stupid game "who runs on oil longer". Winner will get a prize of destroyed engine.
If these steps did not let reduce oil consumption to more or less reputable half of quart per 5k miles, you may try this
staff for piston rings.
And if this does not work, you have something more serious than all these reasons. Visit a good mechanic or drive as is.
Do not use transmission oil as a drive around or idle flush, it might strip the protective anti wear layer away and may not be compatible to modern oil seals, even before you consider any reactions between the different oil types.
The OP has an engine that is drinking oil, so if you use any type of flush it could easily make that
problem worse due to the false oil seal effect.
If the engine is not leaking oil, using a major brand idle use flush just before an oil and filter change might be worth considering IF the OP thinks the block is dirty, but that is probably not the cause of the high oil consumption in this case.
