A/C very high low side pressure
Suburban Washington DC
New to me 2003 Honda Insight that was missing the serpentine belt and clutch was all loose. The big bearing was in pieces so I installed a new clutch and coil assembly made for Civics. Diameter is a little less but that shouldn't be a problem in normal driving. Anyway, the air blows ice cold but after a minute, low side is way too high. Ambient around 80°, engine about 1200 rpm, both fans on. Any idea why it might be so high?
Maybe 72. Will have to see how it feels on a hot day.
Since you are not weighing refrigerant. I would use a vent clip thermometer, and add refigerant slowly with the a/c on recirculate and fan on high.
When you see 38f-40f out of the vent, stop adding refrigerant. I'm going to imagine that the low side pressure would be around 40 or so.
@Chris142 would be the expert here.
I know Mr. Atikovi knows how to use the gages properly, but for others out there, some folks get the impression those knobs are the on-off for the gauges themselves. Nope, they are the on-off for the connection between each gage and the yellow hose. The knobs should be In the closed position when taking the pressures off the system. I hope that makes sense.
