Originally Posted By: gregk24
I went on a drive and rechecked pressure and when the compressor kicks on the pressure spikes up to the mid to upper level of the "green", then when it turns off it goes below the green, is this normal? Also, how often is the compressor supposed to cycle?
I think you have that backward, are you quite sure when it's disengaging? Unless you're connected to the high side (unlikely, the fittings are purposely different), that's really not how it should work. The cooling fans should be turning on when it's running.
For what it's worth, my 2004 CR-V cycled often, maybe 15 seconds of running followed by 5 seconds off, then back on. Seemed far too often, but the dealer checked out the pressures and said they were what they should be. Did it since I drove it off the lot new, but it was always cold for years.
