That always irritated me too, The GM vehicles I have also do that. I believe they have some vehicles now that don't automatically run the compressor at defrost. My Nissans always had the comp use a seperate switch. I think that is the way they force the compressor to run (and lube) periodically for maintenance reasons..also helps dry the defrost air. I would rather have the seperate switch personally, but I also see the benefit for running the comp periodically...not everybody remembers to run it for maintenance reasons, so it doesn't bother me enough to switch it seperately myself. I imagine if you want it seperate there is probably no other tech reason to not do it..if it is out of warranty you can always check with mfgr service dept about why it is automatic on for any other reasons..
