History is my Mothers 98 Park Avenue all decked out every electronic device, gauge etc, and the outstanding 3800 engine with the uhgg intake manifold gasket... It has had the engine replaced due to the gasket going bad, it was cheaper to replace the engine than tear it down replace the damaged internal parts... the engine runs strong, and I'm sure set up for several years it was a documented low mileage engine (~40,000 miles) it does consume oil about 1 to 2 quarts during an oil change which she goes by the OLM which goes off at a set 3000 miles.. I'm going to try to get her in a new maintenance schedule as she drives this car easy, and 90% highway 10% city nice long trips to work around 35 miles each way.
I have some good oil in my stash I'm going to see if I can help find an oil that will reduce oil consumption... mind you the consumption is no problem but Mama don't want to fool with this, and worries all the time about it,, she takes very good care of the car while reading how women don't know, or don't care if every woman was like my Mama you would never have to worry about purchasing a used car about how the oil has been changed !!
The manual states it has a short trip, and long trip indicator light, I'm going to keep up on mileage this time, the short trip is what she has been using, I'm not sure how to change it over to long trip which is 7500 miles. I'm going to run a synthetic oil for testing I hope to reduce consumption by choosing a 40 weight if need be, however I have some Castrol 0w-30 ( Germa Castrol) I'm going to try first, and then move up to either Maxlife 10w-30 or Mobil 1 0-40 ... I also have been thinking about running Rotella 10w-30 in this engine as I have had outstanding success using this oil.. I wonder if the rings have "stuck" or have become coked/dried out deposits from sitting for long period of time in the junk yard ? If so is there anyway to combat this problem other than piston soaks with seafoam etc ? I don't think ARX will be a solution for this engine.
If the synthetics do not work I will just drop back to using a 10w-30 conventional, however I'm really hoping the Mobil 1 0w-40 will work out as I have read so many good things about this oil... and Mama would click her heals 3 times if I can reduce or eliminate the need to add engine oil between changes.. I also know there is no mechanic in a bottle as well, but maybe there is some reduction in a bottle ? Any opinions, solutions, recommendations will be appreciated as my Mama is pretty much disabled having had several back surgeries, and very independent as well... a fine woman, and the best Mama that ever was..
