DuPont Teflon "Chain Saver" OR "Multi-Use Lubricant"
This stuff is the best thing I've ever used on chains so far. Goes on wet, dries, and for the most part, it doesn't really collect that much dirt. It does collect a little, but far less than a traditional chain lube. And the dirt that it does collect is much easier to clean off.
__________________
DuPont™ Teflon™ Chain-Saver Lubricant
A high performance chain lubricant utilizing a patented dry wax formulation. DuPont™ Teflon™ Chain-Saver doesn’t attract dirt and doesn’t fling off. Can help chains and sprockets last up to 5 times longer.
Goes on wet. Sets up to a clean, dry, wax film which will not absorb dirt or grime
Will not absorb abrasive contaminants including paper dust, mill powders, lint and grass
Patented self-cleaning technology sheds contaminants to minimize or prevent abrasive wear
Helps chains work better and last longer
Highly resistant to water wash-off and won’t fling off
Water repelling, helps protect against rust and corrosion
Applications:
Motorcycle, ATV and go-kart chains (o-ring safe)
All bicycle chains – mountain, road, BMX, recumbent, etc.
Garage door chains, springs, rollers and tracks:
Industrial roller & drive chains, fork lifts, conveyors, stackers, forestry/logging chains, paper corrugator stacker and floor conveyor chains
NSF H-2 Listed.
