Heck, I don't know. I have used all these sizes you are showing, and all these types on The Beast, or have some in my stash right now. But rather than the 3614 types I like to use the 3600 type. The 3600 type is longer and holds more oil & has more media but the filter head is compatible. Mainly you need the 3/4-16 thread and the gasket outer and inner diameters need to be close enough to match the mounting plate. And you need enough room for an oversize filter in the first place. My present filter in use is a Bosch 3422.
The Fram and Wix sites are good for figuring out if the mount is compatible. Or you can just take filters out of the box and eyeball the threads/gaskets if your eyes are good enough.
The Fram PH3614 that fits my car, and serves as a source of measurements, has these values; I.D. and O.D. mean inner/outer diameter:
Anti-Drain Valve YES
Gasket I.D. 2.47"
Gasket O.D. 2.75"
Gasket Thickness .19"
Gasket Usage Base
Product Height 3.34"
Product I.D. 3/4-16 Thread
Product O.D. 2.98"
Relief Valve Setting PSI 12
