Subaru Factory Fill
3864 miles
Subaru WRX STi
Car was gently driven for the most part with some hard pulls after 1000 miles for break in purposes. Some stop and go daily commuting. I wish I had changed this oil sooner but I don't think it's that bad for a first oil change. I expected high iron and silicone. It currently has a fill of 5w-30 Redline and I plan on running this for 5000 miles and have another analysis. Of note, no oil needed to be added before this oil change so it looks like everything has seated well in the engine.
Blackstone Notes:
Thanks for the notes. Your new STi put more metal and silicon into the oil than normal, but that's common for the factory oil. Universal averages show how the EJ25 Turbo tends to wear (post wear-in) with oil that's been in use about 3,900 miles. The only other thing to point out is the viscosity, since it was a little thin for a 5W/30. That wasn't from excess fuel thinning it out, so maybe your Subaru left the factory with 5W/20. It's not a problem either way. Go ahead with your plan to run 5,000 miles on the next fill, and check back to monitor wear-in progress.
Code:
MI on Oil 3864
MI on Unit 3864
Sample Date 02/26/16
Make Up Oil Added 0
Oil Type Subaru Factory Fill
Universal Avgs
ALUMINUM 6 6
CHROMIUM 1 1
IRON 27 27
COPPER 70 70
LEAD 0 0
TIN 1 1
MOLYBDENUM 1061 1061
NICKEL 0 0
MANGANESE 4 4
SILVER 0 0
TITANIUM 0 0
POTASSIUM 4 4
BORON 165 165
SILICON 123 123
SODIUM 6 6
CALCIUM 2034 2034
MAGNESIUM 21 21
PHOSPHORUS 895 895
ZINC 1006 1006
BARIUM 4 4
SUS Viscosity @ 210°F 51.6
cSt Viscosity @ 100°C 7.75
Flashpoint in °F 385
Fuel %
Antifreeze % 0.00
Water % 0.0
Insolubles 0.2
TBN N/A
3864 miles
Subaru WRX STi
Blackstone Notes:
Code:
MI on Oil 3864
MI on Unit 3864
Make Up Oil Added 0
Universal Avgs
ALUMINUM 6 6
CHROMIUM 1 1
IRON 27 27
COPPER 70 70
LEAD 0 0
TIN 1 1
NICKEL 0 0
MANGANESE 4 4
SILVER 0 0
TITANIUM 0 0
POTASSIUM 4 4
BORON 165 165
SILICON 123 123
SODIUM 6 6
CALCIUM 2034 2034
MAGNESIUM 21 21
PHOSPHORUS 895 895
ZINC 1006 1006
BARIUM 4 4
Fuel %
Antifreeze % 0.00
Water % 0.0
Insolubles 0.2
TBN N/A
