- Joined
- Apr 16, 2023
- Messages
- 23
So, I have just acquired an '09 EX-L Ody and intend to do a super tune-up job myself before reselling it!
I've been researching for HOURS and this is what I'm planning on trying.
(I posted all the fluid change ideas in another thread)
Let me know your thoughts on this!
Here's the list in no specific order:
1. Install VCM Muzzler (VCM Tuner II)
2. Replace all 6 spark plugs with NGK Ruthenium HX
3. Install Dorman 42009 SP non-foulers
4. New PCV valve
5. New timing belt
6. New water pump
7. Replace air and oil filters
8. New ignition switch lock cylinder
9. New sliding door center rollers
10. Clean engine components such as the mass air flow sensor with carb cleaner
11. Check for other errors in the car and fix as needed
I have good knowledge of recent maintenance from before I received the car, so I'm only doing the other items.
4. New PCV valve
5. New timing belt
6. New water pump
