Hello folks,
I'm just itching to bond with my new Ranger and change the factory/break-in oil. I've got 1100 miles on it and I'm trying to figure out which oil and oil filter to employ. My commute to work is 1.3 miles, made when the engine is cold (about freezing temperature). Several times during the day, I might drive the truck between 5 and 20 miles. My Ranger came with the 5-speed automatic transmission. Should I seriously consider performing some early preventive maintenance on that -- or elsewhere? I've heard some folk impugn the quality of Ford automatic transmissions; I'd like to do everything I can practically do to make sure mine continues to put out.
I have the mental image of shrapnel running wild inside my engine/transmission, since it is quite new. Is this accurate?
Thank you folks for sharing your time and wisdom.
-Chad
-Chad
