Previous CO-OP UOA: Click here
I switched from CO-OP DMO SL 0W-40 because the 6.0L runs better on a 30 wt.
Oil performed just as good (or better) TBN is lower after the same amount of time using the ESSO oil.
Only difference with this sample is I got the engine really hot before I drained it to get the fuel dilution out as best I could as the last sample had 2.0% fuel.
John Deere oil scan (Edmonton Lab)
Hours on Unit: 1339
Hours on Oil: 272 Hours
Kilometers on oil: 17,564
Metals (ppm)
Iron (Fe) 31
Chromium (Cr) 1
Lead (Pb) 4
Copper (Cu) 4
Tin (Sn) Aluminium (Al) 5
Nickel (Ni) Silver (Ag) Titanium (Ti) Vanadium (V) Contaminants (ppm)
Silicon (Si) 8
Sodium (Na) 4
Potassium (K) Water (%) Coolant No
Fuel (%) Soot (%) 0.8
Additives (ppm)
Magnesium (Mg) 91
Calcium (Ca) 1670
Barium (Ba) 4
Phosphorus (P) 1359
Zinc (Zn) 1659
Molybdenum (Mo) 4
Boron (B) 51
Physical Tests
Viscosity (cSt 100C) 11.1
Physical / Chemical
Base Number (mgKOH/g) 6.6
Hours on Unit: 1339
Metals (ppm)
Iron (Fe) 31
Chromium (Cr) 1
Lead (Pb) 4
Copper (Cu) 4
Silicon (Si) 8
Sodium (Na) 4
Additives (ppm)
Magnesium (Mg) 91
Calcium (Ca) 1670
Barium (Ba) 4
Phosphorus (P) 1359
Zinc (Zn) 1659
Molybdenum (Mo) 4
Boron (B) 51
Physical Tests
Physical / Chemical
