This is my Blackstone analysis after 12,486 miles under pretty heavy towing. Recommended OCI under heavy loading is 15k miles. Under light loading they don't give an OCI. The truck has 84k miles. The oil has been changed at least twice previously. The first numbers are mine and the second are the universal averages (which is based on 17,740 miles). It's Mobil 1, 75W90 synthetic. The gear oil still looked new.
ALUMINUM 2 2
CHROMIUM 2 2
IRON 304 220
COPPER 6 2
LEAD 0 1
TIN 0 1
MOLYBDENUM 0 1
NICKEL 2 2
MANGANESE 14 15
SILVER 0 0
TITANIUM 14 13
POTASSIUM 1 2
BORON 130 210
SILICON 9 60
SODIUM 11 10
CALCIUM 24 58
MAGNESIUM 2 5
PHOSPHORUS 1704 1938
ZINC 66 34
BARIUM 1 1
Their comments were as follows:
GARY: Amended report to correct equipment type. Universal averages show expected metal readings after about 17,740 miles on the oil for a Dodge Ram. You haven't yet run this oil quite as long as average, though iron is already a little higher. Maybe your truck works harder than most and that explains the extra iron, which comes from steel parts. The viscosity was fine and no moisture was found. Insolubles are nice and low. No obvious problems were found here, though we'll be watching iron in the future. This oil should be fine with 3,000 more miles of use.
The previous oil had about 30k miles on it.
I'm thinking of using the 75W140. We run it primarily in warmer parts of the country.
Any comments?
ALUMINUM 2 2
CHROMIUM 2 2
IRON 304 220
COPPER 6 2
LEAD 0 1
TIN 0 1
MOLYBDENUM 0 1
NICKEL 2 2
MANGANESE 14 15
SILVER 0 0
TITANIUM 14 13
POTASSIUM 1 2
BORON 130 210
SILICON 9 60
SODIUM 11 10
CALCIUM 24 58
MAGNESIUM 2 5
ZINC 66 34
BARIUM 1 1
Any comments?
