- Joined
- Nov 20, 2021
- Messages
- 1,603
A friend and customer of mine has a 2004 Chevrolet Impala with a 3400 V6 and the 4T65E transmission, about 115K on the car as of now. About twice a month he travels to his family's land to check everything over, and to get there he has to ascend a small mountain. To pull the grade he uses manual second gear, then shifts back to overdrive once he reaches the top where it plateaus. You really need to pull this ascent the way he does in this car. When he pulls this grade the transmission begins to whine only once engaging manual second, and by this time we've driven close to thirty miles. After reaching the top and shifting back to overdrive, it still whines when the car shifts itself to second, whether upshifting or downshifting. The transmission never slips, shudders or struggles to pull, just whines. We get there and park the car, I rode along because he wanted me to hear the noise and I had nothing else going on. Only took him about half an hour to scan the place over. After the car sat that time we headed back home, and the noise did not return at any point regardless of second gear engagement. The transmission fluid is full, and was serviced last year using Mobil 1 ATF, which doesn't meet Dexron 6 but does meet Dexron 3 specs. It also has a bottle of Lubegard added. The mountain climb is the only time it ever whines, but it gets pretty loud.
I do some light mechanic work as some of you know, but I am not a transmission man. I can change the fluid and change the whole units, but I've never actually cracked one open beyond changing the internal filter. Any ideas on what the whine might be? Perhaps the Mobil 1 is too thick? I really don't have an answer for him.
Thanks.
Thanks.
