sometime back, I hv posted a topic on soaking the engine with kerosene overnight and drain it off on the next day to clean up the engine (without firing the engine at all)... Some members was commenting that might be a bad idea...
Im not really into getting engine flushing chemicals as i believe these chemicals are just plain kerosene packed in a nice tin... Might as well getting some kerosene at harwarestore at a friction of the engine flush price...
I was thinking for the alternative way that could be safer and more efficient... There are people flushing their engine with ATF, which could be safer than Kerosene but problem with ATF is, the detergent in the ATF is so low that it might be a better idea getting some 0W20 engine oil to and run in with a shorter OCI...
Undestand that 2 cycle oil is one of the best oil in lubrication (just imagine, it has to be efficient enough to lubricate the piston and rings b4 it burns off as exhaust fume)
Good quality 2 cycle oil with TCW3 and Jaso FD rating is also known to be very effective in clearing the carbon within the combustion chamber (again, imagine that the 2 cycle oil has to do its job before it burned off in the matter of miliseconds..)
If 2 cycle oil is mixed with engine oil at the ratio of... say 1:3 and run it for a thousand miles before oil change... will this efficient enough to "flush" the engine?
Any comment is welcome... afterall, its just my wild idea...
