So upon startup the truck smokes quite a bit. The smoking stops after driving a couple blocks. After it quits, it doesn't smoke, at any other time while it is being driven. I am assuming it is the valve seals. What is the harm in continuing running it this way? And if anybody knows what it approximently would cost to repair at a shop. The engine is a 2.9l, and it does not overheat while running, nor does it loose coolant.
