Blackstone Labs Report: 08/27/12
11 Chevrolet EQUINOX
GM 2.4L 4-cyl EcoTec
Gasoline (Unleaded)
AC Delco 5W/30 Dexos1
Makeup oil added: 0 qts
There was a fair amount of metal here. Universal averages are based on 6,000 miles on the oil, so your longer run might account for some metal, but it wouldn't explain all of this metal. Aluminum shows piston wear, chrome is from rings, iron comes from steel, and copper is from brass/bronze. Perhaps some of this is residual wear-in, if your engine had only 2 oil changes so far, though another possibility is that silicon is dirt and it accounts for some metal. The low viscosity and 1.0% fuel are harmless. TBN is low at 0.8, so stay with ~9,500 miles and check the air filter.
Code:
Miles on Oil: 9,478 Miles
Miles on Vehicle: 21,138
ALUMINUM 9
CHROMIUM 4
IRON 95
COPPER 9
LEAD 1
TIN 2
MOLYBDENUM 77
NICKEL 2
MANGANESE 7
SILVER 0
TITANIUM 0
POTASSIUM 6
BORON 61
SILICON 21
SODIUM 12
CALCIUM 1898
MAGNESIUM 20
PHOSPHORUS 616
ZINC 680
BARIUM 0
PROPERTIES
cSt Viscosity @ 100°C 53.5
SUS Viscosity @ 210°F 8.34
Flashpoint in °F 345
Fuel % 1.0
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.4
TBN 0.8
Had 18% left on the OLM at the time of oil change. Given the low TBN and metals, my amateur opinion is that following the OLM on Dexos1 would have been a stretch. To the analyst's point on the air filter, I changed it at 16,000 so the first 5k of the OCI were on a dirty air filter. 70% Freeway driving
Gasoline (Unleaded)
Code:
ALUMINUM 9
CHROMIUM 4
IRON 95
COPPER 9
LEAD 1
TIN 2
MOLYBDENUM 77
NICKEL 2
MANGANESE 7
SILVER 0
TITANIUM 0
POTASSIUM 6
BORON 61
SILICON 21
SODIUM 12
CALCIUM 1898
MAGNESIUM 20
PHOSPHORUS 616
ZINC 680
BARIUM 0
PROPERTIES
Fuel % 1.0
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.4
TBN 0.8
