NAPA syn at $3.49/qt would be a good deal and is an Ashland product either close or identical to Synpower.
You can register this '12 for both the Pennzoil and Quaker State "engine warranty" rebates and get twenty bucks MIR on a jug each of Plat and QSUD 0W-20.
Wally is clearancing the QSUD at many stores for $17.00, so you'd even be a couple of bucks ahead.
You could also stash some Plat 0W-20 using the current ten buck MIR as well as FRN credits, which provide for substantial savings on fuel at participating Shell stations.
I have a nice stash of Idemitsu HGMO, as well as a few changes worth of Amsoil SSO 0W-20 so I won't be needing oil for my '12 Accord for quite some time.
I'll second those who've written that you should change oil by the IOLM.
When the MM hits 15%, start thinking about an oil change, rather than every 6K.
I went to 8700 and 15% MM on the FF, since Honda is adamant about running a full interval on the FF, while the second run, under different driving consitions yielded but 6.5K to 15% MM.
If your car has an IOLM, and your Honda does, use it to save yourself some dollars on unecessarily frequent drains.
