Oh my... a GM DI engine, with VVT and cylinder deactivation? And they are going to lighter oil too?
Those things will definitely keep BITOG hopping in the future!
Trav said:As long as the crank is at least nodular iron (preferably forged) and the bottom end is reinforced enough to eliminate flex any engine can be bullet proof on 20w or even lighter oils.
This is where my problem with this wholesale recommending of 20w arises.
Oil capacity and volume alone are not enough but regardless some will recommend 20w as a matter of course because another engine in the same family uses it without taking crank material, finish or block rigidity into account.
If everything is right there is absolutely nothing wrong with 20w or even lighter oils.
Its inevitable when the new 5.3 is out that some genius pops off with "well in the new 5.3 they spec 20w so it must be okay for the old ones".
You're waving the red blanket at the raging bull.
