Hi guys,
This is my very first post, and i'm thrilled to having been allowed to join this forum. Skip the introduction and go to "My question", if you just want to help and are short on time - thanks!
Introduction
I drive a BMW E39 520 from 1997. The car has gone roughly 300,000 km. The engine had been replaced before I purchased the car last year, with one that had gone roughly 160,000 km, now one year later it's at about 170,000 km. I don't know how the car was driven by the previous owner, but I replaced the engine oil with 5W-40 (I forgot the brand) shortly after I received it.
Specifications
Car: BMW E39 520 1997
Engine: I6 24V 1991 cc
Owner manual recommends: Everything from 5W-20 to 15W-40 depending on the environment you live in.
Environment: Summer (25+ C), Winter (-5/-10 C)
Driving pattern: Daily trips of 2 x 10-15 km (35-40) min one way). I usually don't rev over 3,000-3,500 until the engine has gotten warm, which is probably just around when I arrive at my destination.
Engine oil
I took interest in engine oil shortly after I first changed oil last year, and I read a brilliant article by Dr. Haas, which dispels all the common misconceptions people have about oil, even here in Denmark - people told me 0W-30 and 0W-40 was much too thin for my car... yes, this was the reason I ended up scouring the internet for information about engine oil and viscosity in the first place.
My question
I'll be changing engine oil soon, and i've been doing some digging. I got very confused when I found out that 5W-XX oils of the same brand in more than one case were thinner at 40 degrees Celsius than the corresponding 0W-XX oil:
Castrol Edge 0W-30 (DK)
Product data sheet: 13-06-2007 - Viscosity @ 40C / 100C: 72.0 / 12.2 (API SL, BMW LL-01)
Castrol Edge 5W-30 (DK)
Product data sheet: 20-12-2005 - Viscosity @ 40C / 100C: 70.0 / 12.0 (API SM, BMW LL-04)
Shell Helix Ultra 0W-40 (pdf) (US)
Product data sheet: Viscosity @ 40C / 100C: 75.2 / N/A
Shell Helix Ultra 5W-40 (pdf) (US)
Product data sheet: Viscosity @ 40C / 100C: 75.0 / N/A
So I read up on the SAE J300 classification system, and found out that the XW part was determined by a Cold Cranking Simulator (CCS) where oils depending on their cranking viscosity and pumping viscosity at different temperatures (as well as a minimum viscosity at 100C) determine their rating. So can I assume that even though the 0W-XX oils i've been looking at have a slightly higher viscosity at 40C they will outperform the 5W-XX oil at extremely low temperatuers?
I'm interested in an oil as thin as humanly possible (cold), because the car only drives short trips and gets turned off as soon as it's warm. So in my case which would you recommend? The Castrol Edge 0W-30 (BMW LL-01) or the 5W-30 (BMW LL-04). I personally think i'll get the latter, unless someone provides compelling evidence that it's much thicker below 40C than the 0W-30 oil. I was actually hungering for a 0W-XX all year...
Thanks a lot for reading
*Update*
The thing is that I assumed that 0W > 5W+ would always be the best if you wanted to prevent wear at startup, but if you live somewhere where it's 40C a 5W will be thinner than a 0W oil, at least when comparing Castrol Edge and Shell Ultra Helix oils.
If only they would release viscosity charts for more temperatures.
Introduction
Specifications
Engine oil
My question
*Update*
