All samples with the exception of the prior one dated 11/28/2019 are 0w-20 Mobil 1 EP. The prior sample was 5w-30 Mobil 1 EP. Going forward that will be the oil of choice.
Not if you adjust for the OCI. Iron was 2.85 per thousand miles on this sample vs. 1.73 per thousand on the 5w-30. That's a 65% increase.Wear looks basically the same.
and the funny thing is that the 5w-30 has like no pao while the 0w-20 does yet it did better.TBN was better with the 5w30?
but but but muh oil analasys proves nothing 0w-20 is just has good ...... nah thicker protects more.Not if you adjust for the OCI. Iron was 2.85 per thousand miles on this sample vs. 1.73 per thousand on the 5w-30. That's a 65% increase.
"If viscosity were an issue..."It also took almost 2 years to get this sample compared to
Remember that most iron parts of the engine do not operate in hydrodynamic lubrication. Cylinders walls, cam lobes and lifters, timing chains, etc... all operate in boundary and elasto-hydrodynamic lubrication. The rings briefly go through hydrodynamic lubrication around peak piston speed of the stroke.
If the viscosity were an issue, I would expect more copper and lead (bearing) wear, not iron. Unless the bearing material is different. It could be weaker additive response and less surface tension with the high PAO content allowed condensation to promote rust over the long (time) OCI. I'm just speculating though.
Regardless, I would probably use M1 EP 5W-30 and change it once a year or 10,000 miles.
"Regardless..."
Regardless of what ?
Regardless of the fact the Honda says to use thin oil ?
Regardless of the fact that this is a 2016 Accord ?
Everything except your last paragraph.
Cheap SP 0W20.
5k mile OCI.
10k mile OFCI.
IMHO.
You keep saying that like it means something.People trying to use a UOA to demonstrate that one oil is better than another have a serious and complete misunderstanding of how a $30 spectrographic analysis works. Or just a total lack of understanding of basic scientific method. One or the other.
Blackstone themselves state that there is no statistically significant difference in UOA results between the oils they test. The UOA gives a glimpse of how the specific engine is operating under specific operating conditions, it does not reflect "how good the oil did."
