Not sure, we are in warmer climates. Hopefully when i go to a 30wt it will not consume or make piston slap noise.
Another cool thing about this truck. Usually i have to remove interior lights so i can leave the door open with the radio on and no lights attracting mosquitos and burning down the battery.
A bad point, the cd player only comes on with the key in the run position. Used to be, you turn the key backwards and listen to tunes. Also, it has automatic lights, yet they can be used manually, but you have to turn e switch every time you get in. I think there is a mod forthis, however.
The cig lighters dont work, so hopefully i wont get any CELs when i change out the fuse, that is, if that is the solution.
Also, found a manual for my radio, got it all setup and it doesnt sound that bad. I think it is the old Roadmaster brand.
Also, i just had someone disengage the auto correct on my iPad, so you wont be reading any crazy words anymore. It seems here at BITOG, we dont use ordinary language.
