Hi Tempest,
The ester used here is a diester. We have esters that can do better, such as our advanced POEs, but these are designed for more severe applications, so using such an ester here would not be a fair comparison.
We have not found this test to correlate strongly to volatility but it does correlate well to oxidative stability and polarity, with polarity often the largest factor. This is why the Group I shows reasonably well as it has aromatic compounds that contribute to polarity and hence solubility. Oils that have good oxidative stability breakdown slower, and oils with good solubility (polarity) can dissolve and/or disperse the breakdown products - that is, they clean up their own mess.
All of the oils used here are premium examples of ISO 100 R&O oils, specifically air compressor oils, that were formulated and optimized by their manufacturer. We felt this would be more fair than putting the same additive package in each of the base oils as they may respond differently. In any case, this particular photo was intended to give a visual representation of how the various classes typically perform in this test and not to make a scientific comparison of specific lubricants. We have consistently seen Group III and PAO formulations give more deposits over the many years we have run this particular test.
You are correct that this test is very severe and the results say nothing about performance in motor oils. The test was designed for jet engine oils where it is quite useful, and the photo is generally used to show the cleanliness properties in high temperature applications that are prone to coking, such as turbine engines, oven chains, and reciprocating air compressors.
There are esters that will perform poorly in this test, such as vegetable oils and oleates, but the types of saturated synthetic esters generally used in high temperature applications all do better than the Group III and PAO formulations that we have seen. That said, I still believe Group IIIs and PAOs offer the best value as the main component in synthetic car engine oils since varnish and carbon deposits are rarely a problem, and pure ester could lead to some seal problems. For the real severe high temperature industrial and aviation applications where coking is a problem, 100% ester based oils are the way to go.
Tom
