Does anyone here have a disabled child?
by SLO_Town. 07/20/19 07:08 PM
Synthetic 5W30 D1/Gen2 vs. Synthetic 10W30 ?
by ChrisD46. 07/20/19 07:00 PM
ECOGARD X4612 NEW FILTER CUT OPEN
by 53' Stude. 07/20/19 06:48 PM
Show me your dinner
by 53' Stude. 07/20/19 05:52 PM
Shelf life of Gumout fuel injector cleaner
by pentode. 07/20/19 05:24 PM
Started a big job on the Carrera
by rooflessVW. 07/20/19 05:17 PM
Taco Bell Cantina
by vavavroom. 07/20/19 05:13 PM
TEC SELECT T 4612 CUT OPEN
by 53' Stude. 07/20/19 05:01 PM
2012 Ford 3.0 V6 Kendall GT-1 5W-20 6488 mi
by AITG. 07/20/19 04:37 PM
Replaced All Signaling Bulbs At One Time
by RayCJ. 07/20/19 04:21 PM
Cheryl's New She Shed
by MolaKule. 07/20/19 04:16 PM
Thread sealant for bolts holding diff cover.
by Snagglefoot. 07/20/19 03:30 PM
Meguiars Hybrid Ceramic
by rdevans89. 07/20/19 03:02 PM
2015 Mitsubishi Outlander GT trans. filter
by Kira. 07/20/19 03:02 PM
Could microglass/synthetic media filters harm engines?
by Deontologist. 07/20/19 01:47 PM
A/C problems 2016 Nissan Quest.
by JTK. 07/20/19 01:37 PM
change once a year regimen
by alex_at. 07/20/19 01:34 PM
What would you like to do in the future?
by Red91. 07/20/19 12:45 PM
Roadtripp, Denali376, GoldDot40, Dtn2, Bonebender
68717 Registered Users
107 registered members (53' Stude, 4WD, 08z06, AdditiveOCD, 2004tdigls, 007, 5 invisible), 1,890 guests, and 27 spiders.
Topics292,161
Posts5,017,849
Members68,717
Most Online2,967
Mar 10th, 2019
BMK-13 Bypass & Prelube Pump Insallation #762080
11/05/06 04:52 PM
11/05/06 04:52 PM
Granville, Ohio
slalom44 Offline OP
slalom44  Offline OP
Granville, Ohio
On 5/30/04, I installed an Amsoil BMK-13 Dual Remote Bypass Filter and a prelube pump on my í03 Honda S2000. I did a great deal of research on oil filtration systems before I came up with this setup. My car had 5,997 miles when I installed it. Hereís what I did:
I removed the stock oil filter and screwed in the adapter supplied by Amsoil. From there, I ran hydraulic lines to and from the Dual Remote Bypass filter setup which was mounted on the sidewall near the filter. I had to use some customized fittings to get it to fit in this area, since the Amsoil fittings took up too much space.
At the inlet to the BMK-13 unit, I installed an 8AN tee, and had a hydraulic line coming from a ShurFlo 3GPM pump. I installed a low-pressure hydraulic line from the oil drain plug to supply oil to the prelube pump. This pressurizes the entire system at startup.
Hereís how it works: When I get in the car, I trip a toggle switch that I have clipped on the the bottom of the dashboard. This sends an electrical signal to a relay under the hood, which powers the prelube pump. This pumps cold oil to the inlet of the filters, pressurizing the entire system. I installed an oil pressure gauge, so I can see the pressure climb (typically to around 30 psi) in around 5 to 20 seconds, depending on how cold the oil is. Once the system is pressurized, I start the car. Since I kept the oil pressure switch hooked up, the car never runs without oil pressure. Once the car is started, I flip the toggle switch off, turning the pump off.
This pump is an on-demand pump, meaning that if it is turned on it pumps until the pressure exceeds the preset limit, then turns off until it hits the lower preset limit. So If I forget to turn off the pump, it turns off automatically, but kicks back on when the oil pressure dips below around 30 psi. I also installed an LED on my A-pillar that goes on whenever the pump is running so I know when I forgot to turn it off. It doesnít do any harm to just keep it on, but this pump wasnít designed for constant hot oil use, so I donít want to push my luck.
Hereís how it looks under my hood (with the air filter housing removed for a better view)
As you can see, it is shoe-horned in there, but itís a clean installation. I had to fabricate custom brackets to mount the Bypass Filter and Prelube Pump. You can see a braided hose above the Bypass filter. This comes from the Oil Pressure Sender port, and I have the pressure sender and pressure switch mounted on the end of the braided hose to prevent vibration fatigue. The blue fittings coming from the Bypass filter and prelube pump are the two ends of one line. I had too loop it just to get it to fit.
Hereís another view of the setup. The red wires on the left are connected to the relay switch. I have it set up this way so that I didnít have high current traveling to the toggle switch under the dash board.
Hereís a picture of the drain plug hookup. This is a hollow plug screwed into a 6AN barbed fitting. Itís really easy to disconnect this when I change the oil. And because this pump setup can be run dry, oil changes are quick and I can purge practically all of the oil in the car. And when I fill the oil back up, I turn on the pump and pressurize the entire system before I start the car.
I picked the prelube pump up on Northern Toolís website. Itís not designed for this application, however the specs on it suggested that it would work fine. I called up ShurFlo and asked one of their tech guys if he thought it would work, and he didnít see any reason it wouldnít. Itís been working now for 2 Ĺ years now and over 26,000 miles without any problems. The pump is Model #2088-343-135, which is rated at 3 gpm. It does a good job of pressurizing my system up to around 30 psi at startup. The built-in check valve prevents backflow of oil back into the oilpan. I have the oil pressure gauge to make sure everything is working as it should. Iím using Amsoil Series 2000 0W-30 oil. The 0W- allows it to flow better when cold, which allows the system to pressurize quickly at startup.
Granted, this is way overkill, but I just wanted to see what I could do. This engine should last forever with this setup. I just had a UOA done on the last oil change, which can be seen here:
http://theoildrop.server101.com/forums/s...ge=0#Post753919
Notice that with over 14 months and 12,691 miles since the last oil change, this setup is working great. The wear metals are low, and I still have a TBN of 6.2 left. And even with all these miles, the viscosity hardly changed. Here is a VOA on this oil: http://theoildrop.server101.com/forums/showflat.php?Cat=0&Board=UBB11&Number=473934
With a UOA like this, Iím comfortable with a yearly OCI. Amsoil has come up with an improved version of their bypass and full-flow filters, but Iím going to use up my stash before going to the new filters. Hereís what Iíve been using:
Re: BMK-13 Bypass & Prelube Pump Insallation [Re: slalom44] #762081
11/06/06 06:34 AM
11/06/06 06:34 AM
los angeles
daves66nova Offline
daves66nova  Offline
los angeles
can i use these 2 filters with a regular dual-remote filter setup?
THIS SPACE FOR RENT, PLEASE PM ME.
Re: BMK-13 Bypass & Prelube Pump Insallation [Re: daves66nova] #762082
11/07/06 07:53 AM
11/07/06 07:53 AM
Granville, Ohio
slalom44 Offline OP
slalom44  Offline OP
Granville, Ohio
Yes you can. However, Amsoil has come out with a new line of filters, and you may not be able to purchase the ones I show any more. The new bypass filter is the EABP-90, and the new full-flow filter is EAO-15.
Re: BMK-13 Bypass & Prelube Pump Insallation [Re: slalom44] #2995835
05/07/13 08:42 PM
05/07/13 08:42 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Sweet setup. Thanks for Linkin the old thread.
2012 Chevy Cruze LT 1.4T - 62k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: BMK-13 Bypass & Prelube Pump Insallation [Re: slalom44] #3003497
05/15/13 09:40 PM
05/15/13 09:40 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
You are living proof that overkill is just the right amount. Especially if you have a really nice car. And now for the next frontier. How about a filter for your cooling system. You can't be too careful you know.
Re: BMK-13 Bypass & Prelube Pump Insallation [Re: OneEyeJack] #3010106
05/22/13 05:59 PM
05/22/13 05:59 PM
Granville, Ohio
slalom44 Offline OP
slalom44  Offline OP
Granville, Ohio
Thanks. smile
Here is a link to the UOA that prompted this thread to be resurrected:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2995702#Post2995702
Re: BMK-13 Bypass & Prelube Pump Insallation [Re: slalom44] #3514534
10/18/14 02:21 PM
10/18/14 02:21 PM
Sk, Canada
zpinch Offline
zpinch  Offline
Sk, Canada
Hey Slalom, check out my new bypass setup in a 2003 Honda CRV, dual remote running 5w20 SS. Only ran 5000km on the first analysis, but I want to get a good trend analysis going. The oil looks barely used.
2003 Honda CRV w/217,000km
AMSOIL remote bypass filter (EAO15 & BP90) & EAA
Signature Series AZO 0w30 - 41,000km+ on bypass unit/oil
Re: BMK-13 Bypass & Prelube Pump Insallation [Re: zpinch] #3514558
10/18/14 03:20 PM
10/18/14 03:20 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
5,000 miles the IS barely used.
2015 F150 2.7
2018 F350 6.2
Re: BMK-13 Bypass & Prelube Pump Insallation [Re: slalom44] #3514559
10/18/14 03:23 PM
10/18/14 03:23 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Nice install job and you can tell lots of thought went into the installation.
2015 F150 2.7
2018 F350 6.2
