Engine Make/Model: 2005 Toyota Tacoma 2.7L 2TR-FE
Oil: Pennzoil 5W-30 SM
Oil Filter: OEM Toyota
Miles on oil: 4470
Miles on vehicle: 21990
Blackstone Analysis:
ALUMINUM 2
CHROMIUM 0
IRON 6
COPPER 3
LEAD 0
TIN 0
MOLYBDENUM 240
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 26
SILICON 18
SODIUM 2
CALCIUM 1594
MAGNESIUM 8
PHOSPHORUS 693
ZINC 821
BARIUM 0
SUS Viscosity @ 210F 54.0
Flashpoint deg. F 370
Fuel % Antifreeze % 0.0
Water % 0.0
Insolubles % .3
TBN 2.4
Comments: No problems showed up in the initial sample from your Toyota. All wear read at or below universal averages, which are based on an oil run of 4100mi. Your wear was in the proper balance to indicate normally wearing parts at work inside your 2.7L. The viscosity of the oil was slightly low but no fuel, coolant, or moisture was present to account for the shift. Insolubles were low at 0.3%, showing good oil filtration. Air filtration is working well too. The TBN read 2.4 showing some active additive left. Try 5500 mil next time.
Note: Engine has been slightly overfilled with oil since day 1. Owner's manual says capacity with new oil filter is 6.1 US quarts. I experimented this oil change and found out that 5.2 quarts will hit the full mark on the dipstick with a warm engine and new filter. This is a common thing apparently on this engine as others have reported the same problem on several other forums. I've never run into this problem before on any other vehicle that I've changed oil on. The owner's manual is usually very close in oil capacity. I expect with less oil in the crank, my TBN and viscosity would have degraded quicker, so I'm sticking with < 5K changes.
Side note: I switched to Havoline SM, but it looks like Pennzoil has a decent shot of Moly too!
Miles on oil: 4470
ALUMINUM 2
CHROMIUM 0
IRON 6
COPPER 3
LEAD 0
TIN 0
MOLYBDENUM 240
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 26
SILICON 18
SODIUM 2
CALCIUM 1594
MAGNESIUM 8
PHOSPHORUS 693
ZINC 821
BARIUM 0
Water % 0.0
Insolubles % .3
TBN 2.4
