Alfred Pick / Vietnam Veteran Scam Story
by DoubleWasp. 10/20/18 01:32 PM
Cooper CS5 - 95H or 95V
by Oro_O. 10/20/18 01:25 PM
Leak down tester gauge?
by tomkat22. 10/20/18 12:55 PM
15w40 dino vs 5w40 syn for w/c garden tractor
by bchannell. 10/20/18 12:50 PM
Walmart CANADA Mobil 1 Rollback
by Snagglefoot. 10/20/18 12:43 PM
Subaru 15208AA12A Cut Open 3750kms
by mcwilly. 10/20/18 12:19 PM
Nissan 5.6L Endurance V8
by Zee09. 10/20/18 11:53 AM
TuxMat Floor Mat
by RamFan. 10/20/18 10:56 AM
Axes, hatchets, mauls, etc
by CincyDavid. 10/20/18 10:50 AM
Utility trailer suspension
by Fitter30. 10/20/18 10:48 AM
Oil recommendation for short tripped 83 Chevy
by caprice_2nv. 10/20/18 09:53 AM
To seal or not to seal that is the ?
by twouvakind. 10/20/18 09:47 AM
Popular Science Magazine 1976
by Ether. 10/20/18 09:46 AM
Oil Rec for Audi A4 2.0T TFSI
by Cardiobuck. 10/20/18 09:21 AM
No Poly-tics :) Rambling On
by Zee09. 10/20/18 08:10 AM
Michigan Police Vehicle Test Results
by tenderloin. 10/20/18 08:04 AM
1992 Olds Eighty Eight with 36,000 miles
by atikovi. 10/20/18 07:16 AM
ISUZU 3.9l Diesel 4bd1
by Wreckage. 10/20/18 04:11 AM
unreng, lzhome, keninger, Werdage, Frank_C
66249 Registered Users
74 registered members (2003f7, bcossa2001, anndel, andyd, 1nighttrain, 2K2AcuraTL, 6 invisible), 2,070 guests, and 28 spiders.
Topics292,227
Posts4,876,379
Members66,249
Most Online2,494
Oct 17th, 2018
Page 1 of 7 1 2 7
Brief History of ATFs #729051
04/02/04 12:51 AM
04/02/04 12:51 AM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
A Brief History of Automatic Transmission Fluids for Automobiles and Trucks
By MolaKule
In this tech brief we will discuss the history and specifications of automatic transmission fluids.
See the companion Article:
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=4;t=000147
From the Yahoo reference:
http://ask.yahoo.com/ask/20011022.html
quote:
“As we learned, automatic transmission was based on technology first developed in the early 1900s by German manufacturers of marine engines. However, it was not adapted for automobiles for several decades. In 1938, General Motors developed the first line of cars to sport automatic transmission -- Oldsmobiles that offered "Hydra-Matic drive."
Cars with AT's were first introduced to the public in 1940. In 1941, Chrysler followed suit and introduced three different cars that offered their version of automatic drive, "Vacamatic" (later called "Fluid Drive"). Automatic transmission was a fairly common option on most American cars by 1948.”
Later GM produced the DynaFlow for their heavier and higher priced vehicles such as Buick, Pontiac, and Oldsmobile lines. For Chevy’s and economy models, the PowerGlide 2-speed was developed. Then along came the TurboHydramatic series, the 700-R4’s, and the electronic versions such as the 4L60E and later variations.
Ford had their Ford-A-Matics, Chrysler later introduced their “PowerFlites” about 1953. For these older “Classics” use Dexron III in lieu of any service manual recommendations.
One thing we know for sure is that American hydraulic technology on aircraft spawned hydraulic power in cars. Hydraulic power had been used to remotely control aircraft systems long before it found its way into automobiles.
As Lubrizol says on their website:
quote:
“ATF is the most complex of all lubricating fluids. Not only does it have to reduce friction to prevent wear like all lubricants, but it also has to allow a certain level of friction so clutch materials can engage. Since most OEMs use proprietary frictional materials, virtually every ATF is OEM-specific. In some cases, they're transmission-specific. In addition, ATFs must be compatible with all transmission components, operate at both low and high temperature extremes, and maintain constant performance for extended periods.”
We don’t know much about the early fluids used in these transmissions except they contained additives similar to engine oils and used the better base oils.
GM needed a specification to give to the lubrication industry and the Type A fluid was borne in 1947. Nothing is known about this additive package.
In 1957, ten years later, GM developed the Type A Suffix A fluid specification and we know this fluid contained 16,250 ppm phosphorus, 37,500 ppm sulfur, 18,500 ppm of zinc, 130,000 ppm of Barium. This additive package was 6.2% by volume of the total fluid.
In 1959 Ford issued the M2C33-A/B specification. Nothing is known about that additive package.
In 1961, Ford issued the M2C33-C/D specification. Nothing much is know (at this time) about its additive package.
In 1967 and 1972, GM issued the Dexron specification which contained 3,500 ppm of phosphorus, 3,200 ppm of zinc, 7,500 ppm of nitrogen, 3,200 ppm of sulfur, and 4,500 ppm of Calcium. This additive package was 10.5% of the total fluid volume. The 1972 formulation specified better oxidation and Friction Modification.
In 1967, Ford introduced the M2C33- F “Type – F’” fluid which contained 12,000 ppm of phosphorus, 4,200 ppm of zinc, 4,000 ppm of Nitrogen, and 800 ppm of Barium.
This additive package was 9% of the total fluid volume.
In 1972, Ford introduced the M2C33- G fluid to the European market with slightly better oxidation specs and enhanced Friction Modification.
In 1973 GM specified another Dexron fluid called Dexron II with enhanced friction modification.
In 1974, ford introduced the M2C138-CJ specification and in 1981 the M2C166-H specification. In 1987 they introduced the first Mercon specification.
Mercon V is now specified for use for all AODE and 4R70W transmissions
GM’s Dexron III and III(G) fluids were current fills prior to 2004.
The specifications for a good Dexron III fluid generally show a 7.0 to 7.75 cSt Kinematic Viscosity (at 100 C) and a 40 C viscosity of 35 cSt. Flash points are about 367 F, pour points are -60 F, and sulfur is 2200 ppm with phosphorus being 620 ppm. The SUS viscosities are 17,500 cP at -40 F and 1,350 SUS for -10 F.
Usually you will see this statement for Dexron III/Mercon Fluids:
“The Dexron III/Mercon automotive transmission fluid (ATF) is generally recommended as a replacement fluid for automatic transmissions meeting original equipment manufacturers (O.E.M.) performance requirements for current General Motors, Ford, other domestic and imported passenger cars, vans and light trucks where DEXRON II, DEXRON II-E, DEXRON III, AND Ford/MERCON fluids are specified. The product can also be used as make-up and full fill fluid in Chrysler transmissions; however, it should be noted that Chrysler MS-7176 type fluid should be used when specified to satisfy warranty requirements.
This fluid is recommended for Detroit Diesel Allison C-3, C-4 applications. It also meets the requirements of Caterpillar TO-2. It is further recommended as a service fill fluid for Ford late model C-4 and C-6 transmissions.
The power transmission fluid is suitable for power steering units where the manufacturer recommends a Dexron or Mercon fluid for its systems. Other manufacturer suggested applications include mobile hydraulic and industrial systems, and rotary air compressors under certain service conditions. ” This statement indicates or infers that Dexron III/Mercon is the most universal Automatic Transmission Fluid available and has wide applicability.
GM has released this year (2004) Dexron III(H) fluid specifications for new factory fill’s in their 5 and 6-speed automatics.
Chrysler and others released special specification fluids such as their ATF+ series to avoid shortcomings in fluid and transmission designs.
Better oxidation stabilization, enhanced friction durability, and wear protection was improved with every new fluid introduction and higher specification level.
The ATF has approximately 12-18 different additives in the base fluid, which is generally a paraffinic mineral oil. Later base fluid developments introduced Polyalpha olefins (PAO’s), di-esters, POE esters, alkylated naphthalenes, and alkylated benzenes for better oxidation and thermal resistance.
Of those additives, Ant-Wear (AW) and Friction-Modifcation additives are the most important. Most frictional materials in automatic transmissions are steel making contact with a steel-backed plate containing a surface made of fiber such as cellulose. The cellulose frictional material is bound by resins and may contain other materials such as carbon, asbestos fibers, or ceramics. The frictional materials in future automatic transmissions will contain mostly carbon fiber composites and ceramics.
Each manufacturer uses different clutch materials so the dynamic friction of each transmission is slightly different, hence the requirement for fluids of different dynamic frictional characteristics.
For heavy duty truck transmissions, sintered bronze and semi-metallic friction surfaces are the norm (such as used in Allison Transmissions).
Friction Modification:
When we use the term, “Friction-Modification” with a hyphen “-“ we infer a special friction additive that affects the “Dynamic” friction coefficients under spinning wet-type clutch plates and drums.
Dynamic friction is defined as the “changing of the coefficient of friction as the sliding speed between two frictional surfaces change.”
The friction coefficient of Dexron III/Mercon fluid increases as the sliding speed increases. The friction coefficient of Ford Type F fluid decreases as the sliding speed increases.
Stating the above sentence another way, Ford Type F fluid has a Low Cf at high speeds, and a high Cf at low speeds. Conversely, Dexron Type fluids have a High Cf at high speeds and a Low Cf at low speeds.
Highly specialized Friction-Modification additives determine the dynamic frictional characteristics of ATF’s. The F-M’s must be stable over long periods of usage; i.e., they must not change their dynamic frictional characteristics for at least 30,000 miles. These F-M additives will not show up in VOA's or UOA's.
Also see:
http://www.baumannengineering.com/alphabet.htm
http://www.edmunds.com/ownership/techcenter/articles/43836/article.html
Re: Brief History of ATFs #729052
04/02/04 12:55 AM
04/02/04 12:55 AM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
For a discussion on Chrysler ATF's see:
http://www.allpar.com/fix/trans.html
Re: Brief History of ATFs #729053
04/02/04 02:27 AM
04/02/04 02:27 AM
Airlie Beach Australia
Doug Hillary Offline
Hi,
MolaKule - the first ATF available in 1940-41 was called "Hydra-Matic" and was available from a number of Oil companies
As you know this wonderful and complex range of fluids even survive in the harsh world of Truck, ( manual, auto, retarders etc), Earthmoving and Marine applications
Regards
Doug
Re: Brief History of ATFs #729054
04/02/04 05:25 AM
04/02/04 05:25 AM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
Thanks Doug,
If any BITOG members have other historical data on ATF's they would loke to submit, here is the place.
Re: Brief History of ATFs #729055
04/02/04 02:24 PM
04/02/04 02:24 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Interesting read, thanks Molakule.
Nissan specifies "Dexron/Mercon" OR GL-4 in my tranny case. I've got enought Mobil 1 ATF to do the job, but would a Gl-4 be better ?
Re: Brief History of ATFs #729056
04/03/04 09:03 AM
04/03/04 09:03 AM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
ATF doesn't have the level of Anti-Wear additives I think one needs in a manual tranny, nor does it have a high enough viscosity to maintain a thick fluid film for transmission bearings.
That's why Redline and others have developed fluids like MTL.
Re: Brief History of ATFs #729057
04/02/04 10:55 PM
04/02/04 10:55 PM
North Carolina
needtoknow Offline
needtoknow  Offline
North Carolina
Question,
Why does Ford also spec ATF for their manual trannys as well? My father-in-laws Mustang, my Ranger P/U?
Re: Brief History of ATFs #729058
04/03/04 12:00 AM
04/03/04 12:00 AM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
Because ATF's shift better in cold weather.
Re: Brief History of ATFs #729059
04/03/04 03:56 AM
04/03/04 03:56 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Sorry Molakule, I wasn't clear.
It's dexron/mercon for the 4WD transfer case. Most of the japanese transfer cases are chain drive these days...does this make a difference ?
Re: Brief History of ATFs #729060
04/03/04 04:04 AM
04/03/04 04:04 AM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
Many of the NA vehicles with Transfer Cases are chain drive as well and use a lot of needle bearings. Dexron/Mercon is OK for them. Many transfer cases have oil pumps that need the low temp pumpability of ATF's.
Re: Brief History of ATFs #729061
04/03/04 04:19 AM
04/03/04 04:19 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Thanks again Molakule.
(just checked the Redline Australia website, and they recommend their power steering fluid in the transfer case of these machiens)
Re: Brief History of ATFs #729062
04/03/04 04:24 AM
04/03/04 04:24 AM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
Their PS is just a souped-up (modified) ATF anyway.
Question: Wouldn't that make for an expensive Transfer Case fluid replacement?
Re: Brief History of ATFs #729063
04/03/04 04:29 AM
04/03/04 04:29 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Aye, I beleive that would be a very, very expensive replacement. (Their engine oils are over $30/quart, I've no idea what the power steering fluid is worth)
(I'll stick to the Mobil 1 ATF)
Re: Brief History of ATFs #729064
04/04/04 10:45 PM
04/04/04 10:45 PM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
My Dad reminded me that in about the early fifties, Chrysler introduced the TorqueFlite transmission.
Also, Does anyone recall the Plymouth Push-Button automatic transmission system and what it was called?
Re: Brief History of ATFs #729065
04/04/04 11:17 PM
04/04/04 11:17 PM
California, USA
Jimbo Offline
Jimbo  Offline
California, USA
It was still a TorqueFlite. The push-button mechanism worked a push-pull cable down to the transmission itself, just like a conventional shifter. I saw this up close working on a 1960's Valiant. The bad thing was that the transmission controls looked and felt just like the heater controls. I could picture a driver selecting "reverse" instead of "defrost".
The "727" model of the TorqueFlite is still one of the strongest mass produced automatics ever made, used until recently even behind Cummins turbo diesel engines in Dodge trucks.
Page 1 of 7 1 2 7
