Was wondering if this ATF oil is OK in a 4R100 automatic Powerstroke tranny whic requires Mercon ONLY and NO dual Mercon/Mercon V fluids.
PSnut
PSnut
if you have your original 4R100 or a Ford Reman, then I'd suggest not using any fluid with a dual Mercon & Mercon-V rating. Now if you have a rebuild such as vetteman with his BTS tranny, it's up to the builder to say if Mercon-V is ok. In his case, Brian (BTS) builds his tranny's to not have the Mercon-V issue that plagues OEM 4R100s. Considering that almost all synthetic ATF is going to the Mercon-V rating, I'd recommend Molakule's Autoglide from his company www.specialtyformulations.com .quote:
PSnut
The manual tranny does not have a dual rated prohibition on it. So as long as it meets the Mercon spec, then it is allowed. Now, I am a Schaeffer's fan and have bought close to $600 or so of Schaeffer's products in teh past year. That being said, I think specialty formulations MTFglide is a better choice when it comes to manual transmission use. Insteda of using a Meron rated ATF, which is a comprimise, the MTFglide has the same viscosity as ATF but has a additive and FM pack that ie explicity tailored for Manual tranny's that call for ATF. But If you do want to stick with ATF, then I'm all aboard the Schaeffer's 204sat freight train.quote:
Originally posted by Bob A.:
Will it work in a ZF manual tranny for Powerstroke applications? This transmission is specified to use synthetic ATF. The owner's manual says to use Ford Mercon ATF. It does not say which Mercon though, because Ford brands their as a syn. manual transmission fluid even though it is a syn. ATF. Go figure . . .
I'm currently running AMSOIL ATF which is superior in performance to Ford's very, very expensive syn. ZF 5 speed tranny oil. I'd like to try Schaeffer's if it would meet spec., or if it at least would work well in my transmission.
Following a conversion from a 2 piece flywheel/clutch to a single piece FW/Cltch, I'm fighting a cold shift into 2nd gear and an almost impossible downshift, again, into 2nd gear -- even when at operating temperatures. (No tranny problems prior to the conversion!)
Thanks,
Bob A.
I agree 110% with this statement. I just don't agree with using it for an OEM 4R100.quote:
Originally posted by salesrep:
Our 204sat is a very underated fluid on this board... This is an excellent fluid for many apps.
