Castrol LMA is some pretty stout stuff, at least in my limited testing. As a motocross fanatic, and rider, the rear brake is used not only to slow down, but to change the attitude of the bike in the air, and also to drag through corners while accelerating to load the suspension, and keep the bike from climbing out of ruts. "Normal" brake fluids just dont last long, and turn a dark color really quick from the heat they are exposed to in the rear brake. I tried the expensive fluids from Motul, and Maxima, and did although found them very good, the LMA performs as well for much less money.
I can also echo the ATE quality, but the neatest thing about that fluid is that it comes in two different colors,gold,and blue. No doubt about whether you have all of the old fluid out of your brake system, car, truck or bike, when doing a flush. When the color changes, you know the line, and cylinder are full of the new fluid. A pressure bleeder, some aquarium air hose, a bottle and new fluid, and I can flush and bleed an about 15 minutes, and know its all new fluid.
Just my .02 .
