So I've got some of this stuff and of course they have the "engine guarantee". The 5000 mile number they attach to the label is sort of confusing, especially since most cars these days have longer normal oil change intervals or oil life monitors. Then I checked what the fine print is about their guarantee.
Quote:
http://www.mobil.us/USA-English-LCW/carengineoils_mobil-super-warranty.aspx
Be advised that if your vehicle is covered by a warranty, you should follow the vehicle’s oil life sensor or the oil change interval recommended in your owner’s manual to avoid a disruption in your vehicle warranty. Follow your owner’s manual if the vehicle is operated in any of the following severe services: racing or commercial applications including taxis, limousines, etc.; frequent towing or hauling; extremely dusty or dirty conditions; or under excessive idling conditions.
What The Period Of Coverage Is
The Mobil Super and Mobil Super High Mileage limited warranties are valid for 5,000 miles or your vehicle’s OEM recommended oil change interval, whichever is longer.
I remember the Quaker State guarantee that said they would fix any engine for an oil-related failure if it had been using QS, with the requirement that it only use QS starting at a certain point. Then I read the fine print, and it required that the oil be changed at least every 3000 miles.
