Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
25 registered members (Char Baby, ABN_CBT_ENGR, 87sammy, 77GrandPrix, Amkeer, 5 invisible), 898 guests, and 58 spiders.
Topics306,080
Posts5,286,981
Members71,596
Page 1 of 3 1 2 3
Variable Displacement Oil Pump, 5W-30 to 0W-20? #3076978 07/26/13 01:30 PM
B
Blue_Angel Offline OP
B
Hi all, first post here. I live in Ottawa, Canada, and have a one year old Chevy Cruze Eco manual, with the 1.4L Turbo engine. The car has been great and is averaging 44 MPG for the entire first year of ownership, thanks to my careful driving habits and easy low speed commute.
The car calls for 5W-30 Dexos1 oil. I drained the FF at ~2500 miles (4000kms) and put in M1 5W-30. The OLM had me changing oil around 9950 miles (16000kms) based on my driving. I did so again with M1 5W-30 and a Delco filter. So far so good with roughly 13000 miles (21000kms) now. For the record, I have no loyalty to Mobil1 other than it was the factory fill in my Corvette (so I use there also) and it is cheap and easy to get when on sale at Canadian Tire stores.
I bought this car primarily as a fuel efficient commuter. I read through the "Oil University" posts here and found the information quite interesting WRT start-up viscosity and I'm wondering if I could use a 0W-20 in place of the 5W-30?
My primary driving is very easy, with the engine rarely ever getting above 2000 RPM. Our climate ranges from bloody cold to (relatively) hot and very humid. In the winter months my car barely and sometimes doesn't get to full operating temperature by the time I get to work, even with both upper and lower front grills blocked off and limited use of the heater. Other Cruze owners report oil temps over 250F in hot climates at highway speeds with AC use.
As far as I know WRT engine oil, four key differences that make this engine different from most are:
1. Turbocharger
2. Small displacement
3. Water-to-oil warmer/cooler
4. Variable displacement oil pump
1 & 2 tend to beat up on oil, from what I understand, especially since the Cruze isn't exactly a light car (just over 3000 lbs in Eco trim). 3 seems to indicate that oil temps will rise faster and remain more stable than they would if the engine was not so equipped. Also, I use the OEM oil pan heater in the winter, though it's a low power 200W unit that does little more than keep the oil pan "warm". I do not have the ability to use the oil pan heater at work.
Number 4 is what puzzles me the most in this situation. The variable displacement oil pump operates to maintain a certain pressure to the lower crank case. An oil fed regulator varies the pump displacement and references the oil pressure after the main/rod bearings but before the cylinder head:
http://vauxhall.workshop-manuals.com/astra-j/index.php?id=4646
WRT to engine efficiency: Would the thinner oil require a higher pumping volume from the oil pump to maintain the desired pressure? The way my mind works, this would make sense. If this is the case, would there be any efficiency benefit at all from using a 0W-20 oil over a 5W-30?
WRT engine protection: Would the thinner 5W-20 compromise engine protection at operating temperatures? With my regular driving style being so easy I would assume NO, but I would like to make sure the car is still capable of operating at higher speeds in higher temperatures. With crank case oil pressure regulated precisely by pump displacement, extra flow may be a benefit? Would the lower hot viscosity be an issue for the cylinder head or turbocharger?
Yes, I realise 0W-20 is not Dexos1 labelled… I'm not contemplating the warranty, I'm wondering what's best for my driving with an eye on efficiency and cold start protection. I put about 12000 miles (20000kms) per year on the car and would rather use the same oil year round if possible. Looking for the advice of the experts here. Thanks!
'02 Chev Corvette ZO6: TGMO 0W-20/M1 0W-40, 6:1, HTHSV 2.72, VI 212
'12 Chev Cruze Eco 1.4T MT: M1 0W-30 AFE
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3076995 07/26/13 01:50 PM
2
2oldtommy Offline
2
With your turbo engine, I would not use anything lower than what is spec'ed in your manual. Dexos 1 does include 5w-20 on their approved list but with the turbo, I would use the viscosity that is speced by GM. FWIW---Oldtommy
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077003 07/26/13 01:56 PM
SteveSRT8 Offline
Great choice of vehicle, typically well reviewed and a great tight little car.
With the high tech in that very small but high output engine I cannot imagine deviating from the factory spec. Dexos is a very tough oil, and any brand is going to be pretty nice for you.
The turbo is the hard part for the oil. I would also worry about the variable displacement pump working harder to maintain a certain oil pressure with thinner oil.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077007 07/26/13 02:02 PM
cp3 Offline
First...
welcome
Personally, I don't think a switch to a Xw20 would net much in the way of fuel mileage. What you are doing is probably working very well, that pan heater will likely make more difference than you believe on those cold mornings. I do agree that your use could very likely allow for use of a Xw20 in the winter but I would recommend a pressure and temperature gauge to keep an eye on it. Or a cheap OBDII bluetooth connector and the Torque app on an Android device, not sure what your computer reads and you still might not get oil pressure this way which I would think would be the preferable of the two.
As far as the oil pump and the other points, what you said sounds about right to me but I'm no engineer.
There actually are a couple 5w20s and at least one 0w20 on the dexos1 list I believe.
Dodge Charger|Pennzoil Platinum 5w20|Mopar MO-744
Pontiac G6 GT|Mobil 1 0w40|Mobil 1 M1-101
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077008 07/26/13 02:03 PM
danthaman1980 Offline
Generally speaking, yes I believe in the case of a variable displacement pump, in order to maintain constant pressure, a thinner viscosity oil would result in a higher flow of oil in volume per minute, when compared to a thicker oil.
I'm not sure which would benefit your engine more, but Mobil 1 AFE 0W-20 and several different 5W-20s are now Dexos1 approved.
On an unrelated note - I've visited Ottawa many times on business, it is one of my favorite cities. I make it a point to go drink a Keith's at this little bar below Sparks St whenever I'm there.
2003 Chevy Silverado 1500 5.3 LS Quadrasteer ~239,000 miles (SOLD)
2019 GMC Sierra 1500 5.3 SLT; Factory Fill 0W-20
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077017 07/26/13 02:08 PM
K
KrisZ Offline
K
See that's where the problem lies. While constant low RPMs are nice and easy on oil, accelerating from such low RPM's certainly requires a certain amount of hydrodynamic film strength. And with Cruze's nice low end torque, I would imagine that it can accelerate effortlessly probably even below 2k RPM.
That's where 5w30 and dexos 1 requirement come into play and guarantee that a certain margin of safety was tested for to avoid boundary condition.
If you decide to run anything thinner than that, you're in an uncharted territory.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077021 07/26/13 02:18 PM
J
JAG Offline
J
The variable displacement pump causes a more viscous oil to cause less of an efficiency reduction than a less viscous oil than would be the case with a typical oil pump. The pressure will initially be higher with the more viscous oil and then the system responds by reducing the pump's oil flow rate, thereby reducing pressure to some amount. My answer to your question about this is that assuming the scenario is that the engine is started in very cold temperatures, both thinner and thicker oils may require the pump to reduce the oil flow rate and in order for equal oil pressures to be the case, yes, the thinner oil will have a higher flow rate.
The engineers already thought of many ways to improve this car's efficiency and they specified a 5W-30 oil instead of less viscous ones. I would use what they specified. In the winter, you could probably safely use a less viscous oil but I would not expect to see efficiency gains that are worth the mental stress and warranty implications that deviating from the specified oil (in the thinner direction) may cause. In the warm months I certainly would not use an XW-20 oil. 250F oil temp. is quite high and this engine reaches high torque at low RPMs which reduces oil film thickness in the bearings compared to higher RPMs.
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077023 07/26/13 02:22 PM
demarpaint Offline
That's what I'd use.
Welcome to Bitog.
God Bless Our Troops
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077026 07/26/13 02:24 PM
M
michaelluscher Offline
M
Since your in Canada, how about something like PP 0w-30, Flow's better in the cold, yet robust enough for the turbo...
If you don't care about possible warranty issues, that would be my vote.
'17 CTS Performance AWD 3.6 11K
'06 Camry SE 3MZ-FE 146K
'06 Taurus SE Vulcan 65K
'01 Villager Estate VG33E 55K
'83 Grand Prix LJ 305 SBC 56K
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: michaelluscher] #3077092 07/26/13 03:47 PM
E
ernied Offline
E
why don't you guys just put in what the manufacture recommends or go to college and become an enginer if you doubt them.
2015 Hyundai sonata
2020 Hyundai santafe
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077116 07/26/13 04:22 PM
O
oldhp Offline
O
With that tiny high tech turbo engine use the best 5W30 Dexos approved fully synthetic you can find. What you are using now is very good, the only step up to me would be Pennzoil Ultra.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077147 07/26/13 04:51 PM
G
gpshumway Offline
G
I wouldn't use 0w20 in a Cruze turbo. Since you're in Canada though, you might benefit from a 0w30 oil. Mobil 1 Advanced Fuel Economy 0w30 is one such oil. Idemitsu also makes a 0w30 which is on the Dexos approval list, though I have no clue where you'd buy it.
2007 Subaru WRX
2011 Honda Civic EX
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077230 07/26/13 06:32 PM
H
Hyde244 Offline
H
There is a reason why GM chose 5w30 for this vehicle application - stick with the OEM spec.
2007 Ford Focus ZX4 SES - 2.0L Duratec | 4F27E Auto | 92,000 miles
PU 5w20 | MC 910 | Castrol Mercon V
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: Blue_Angel] #3077236 07/26/13 06:39 PM
Shannow Offline
Oil pressure is the vehicle through which oil is supplied to the engine, it's not a lubrication paramater in it's own right.
Variable oil pump will deliver the required volume to get the pressure, and the thinner oil will have less resistance, so flow WILL go up most cewrtainly...
But oil pressure doesn't lubricate bearings.
Re: Variable Displacement Oil Pump, 5W-30 to 0W-20? [Re: ernied] #3077237 07/26/13 06:40 PM
Shannow Offline
Tried that, and it holds no sway on BITOG...
Page 1 of 3 1 2 3
