Interesting Read
by montero1 - 05/25/20 03:19 AM
1991 Indy 500 Pre-Race
by IMSA_Racing_Fan - 05/25/20 01:46 AM
Repairing acid stained wheels
by IMSA_Racing_Fan - 05/25/20 12:30 AM
Collection of Euro Oils
by js1956 - 05/24/20 10:29 PM
00 grease in my brush mower
by Elkins45 - 05/24/20 09:55 PM
Coolant UV Dye - for without flushing
by Ndx - 05/24/20 09:10 PM
STP S8A C&P
by mpack88 - 05/24/20 07:50 PM
Aprons
by buck91 - 05/24/20 07:35 PM
Oil Additives for GDI engines
by Drew99GT - 05/24/20 07:21 PM
Memorial Day - Veteran's Cemetery
by JeffKeryk - 05/24/20 07:18 PM
CQ Blue, made by who?
by AJB0009 - 05/24/20 06:45 PM
recommended 5w30 for ticking and engine noises
by apollo18 - 05/24/20 06:29 PM
need new group 65 for my F-150, here's my choices:
by DirtyApe - 05/24/20 06:23 PM
Castrol EDGE cleaned my funnel
by AJB0009 - 05/24/20 05:29 PM
Metal Cloak FAD + Fox Steering Stabilizer
by 2015_PSD - 05/24/20 04:55 PM
Blue Driver OBDII
by Al - 05/24/20 04:50 PM
BBC_bias, rabblrouzr, Modoi, zx6rsi, Chumpchange
71522 Registered Users
20 registered members (dishdude, anndel, bachman, ctechbob, daves87rs, bourne, 1 invisible), 1,198 guests, and 26 spiders.
Topics305,828
Posts5,281,084
Members71,522
UCL data? #3036645 06/17/13 10:05 PM
G
GMorg Offline OP
G
Does anyone have a reference for, or experience of, any actual measurements that have shown a benefit of UCLs. Specifically, has any UCL been shown to reduce cylinder, ring, or valve seat wear? Alternatively, has any UCL been shown to reduce friction (when in use) to a point that it increases power, decreases mileage, or reduces ring temperatures? I would be interested in any measured benefit, including fuel pump benefits.
Bottom line, are there real data to show that an additive to fuel can have the effects above.
Re: UCL data? [Re: GMorg] #3036673 06/17/13 10:41 PM
dparm Offline
People seem to believe UCLs are necessary to offset the effects of the ethanol content of gasoline (up to 10%).
Worth noting is that cars running on E85 do have different (read: stricter) service intervals.
The following link has been posted here before:
http://www.ls1.com/forums/f48/been-testing-oil-91206/
2017 Chevrolet Corvette Grand Sport
Re: UCL data? [Re: GMorg] #3036685 06/17/13 10:58 PM
surfstar Offline
GMorg, unfortunately all the BITOG data reported is 'warm, fuzzy feeling.'
What sticks out to me were the brief mentions of FP and LC by Terry. http://www.lcdinc.com/tests.php
I could say I saw an increase in MPG with FP60, but its all in the noise and not statistically significant. Same with Lucas UCL in a previous vehicle.
I don't believe that TCW3 increases MPG. No hard data despite what anyone says. I do use it occasionally and have a hard time discerning any 'smooth' running either. My vehicles just don't respond to fuel adds. If I can't pick out a difference in my MPG spreadsheet, its just a hopeful, preventative maintenance.
2016 Golf Sportwagen 5MT M1 0w40 LC20 RLI BioPlus
my other vehicle is a Roth IRA
Re: UCL data? [Re: GMorg] #3036694 06/17/13 11:09 PM
MrQuackers Offline
Put a tiger in your tank.
Master the 1000 yard stare
coffeeMobil 1 USA
Re: UCL data? [Re: dparm] #3036748 06/18/13 12:51 AM
B
bvance554 Offline
B
That sounds like the same thing they used to say when we went to unleaded gas. Although the lead did serve as a lubricant. They sold UCL's way before they added ethanol to gas and I will never in no way believe that 10% ethanol reduced the lubricity of the gas. I don't look at gas to be much of a lubricant.
To answer the OP's question, I don't think you'll find any data. I think it is at best a placebo.
Re: UCL data? [Re: GMorg] #3036834 06/18/13 06:11 AM
dwcopple Offline
I have gained and maintained a .5 MPG increase since running TCW3 1oz/5gal 6 tanks ago. Cheap enough to keep doing it.
2019 RAM Big Horn 4x4 Blackout HEMI crew cab
2011 Chrysler 200 Limited 3.6L V6
1998 Mustang GT 4.6L V8 convertible
2019 VW Jetta SEL 1.4T
Re: UCL data? [Re: GMorg] #3036914 06/18/13 07:57 AM
G
GMorg Offline OP
G
dwcopple: Would you be willing to share your raw data? It sounds like you have 6 observations for TCW3. How many non-TCW3 observations do you have? Did you switch back and forth or does your experimental design confound treatment with time and seasonal temps? Have you done a switch-back to see if your mileage goes back down? If you share the data, I will run the stats for you.
Re: UCL data? [Re: GMorg] #3037669 06/18/13 07:15 PM
dwcopple Offline
it's in another thread I already started in this section
Re: UCL data? [Re: GMorg] #3038152 06/19/13 09:15 AM
G
GMorg Offline OP
G
DWcopple: Are referencing the thread below? If so, it sounds like you had a single number from a variety of driving styles, you added TCW3 and reset your mileage monitor. You now have a second number, from a different time of year, including what may be a different percentage of highway driving, and now you have a second number. If so, you have a single observation for each treatment and you have confounding factors. I hope your mileage is actually better now, but I know that I cannot confirm that TCW3 is the cause based on the observations in this thread. I suggest that you consider running a this tank down to near empty and then switch back to see if your mileage drops. You will have to do this several times to deal with weather and driving styles.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3015734#Post3015734
Re: UCL data? [Re: GMorg] #3038480 06/19/13 02:10 PM
dwcopple Offline
I didn't reset anything. That gain has appeared and stuck around since I posted the increase.
Re: UCL data? [Re: GMorg] #3039238 06/20/13 07:37 AM
G
GMorg Offline OP
G
I'm a little disappointed at this point in the lack of a robust offering of data or experience.
We do have a Sarge referral and dwcopple's first hand experience. I think that dwcopple's experience is consistent with an UCL effect, but does not prove one yet. If dwcopple's results are representative, his mileage is up much more than he has stated. However, he does not have repetition build into his experimental design. In addition, the presented result is a running average from the time of purchase. The current average mileage includes the historical averages as part of the calculation. This strategy dilutes current effects.
Re: UCL data? [Re: GMorg] #3039961 06/20/13 07:22 PM
Capa Offline
I have never seen a MPG increase from using MMO as an UCL. I just started using TCW3 and just started my third tank and so I am reserving judgment until after the fifth tank or so but right now no gain. However, please note that I always run Top Tier fuel and synthetic oils and I consistently put in a bottle of Techron every 3000-4000 miles.
I will say that I did notice a smoother idle from the UCL, and I am not one to judge oils by noise or the butt dyno like so many here. TWC3 is extremely cheap and so I plan to use up the ST gallon in my two vehicles. When it is gone and then I will decide whether to keep it up or not.
Re: UCL data? [Re: GMorg] #3062424 07/11/13 09:29 PM
MrQuackers Offline
Reduced my emissions vs 2 years ago. I started adding TC-W3 in October 2012. Look at the HC reading. The car is 20 years old and the engine is original.
coffeeMobil 1 USA
Re: UCL data? [Re: GMorg] #3063067 07/12/13 01:33 PM
147_Grain Offline
TCW-3 may have helped remove deposits from the valve seats and the backs of the valves (deposits absorb fuel mixture) to improve emissions.
This UCL also likely helped keep the piston rings from sticking.
2019 Subaru Crosstreck
2013 Subaru Outback 3.6
