I did a drain and fill on my 2003 Mazda tribute. I used Maxlife. The smell of that stuff is wicked strong and now i smell it after i drive. I can assure you i did not spill any and there is no leak. Its not a burnt smell but a fresh smell and at times a hint of something like gear oil. Its very annoying. Has anyone had an issue like this? I could i be smelling it from the vent tube? The transmission is a Ford made CD4E. The truck as 120K on it and the last drain and fill was at 75K, i did one drain and fill with a store brand mercon ATF then drove 500 miles then drained that out and put the ML in.
