Question about Wix filter minder.
Originally Posted By: Silverado12
http://www.ebay.com/itm/330876543652?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Getting ready to order the above for my Chevy truck, but don't know what size hole to drill for the grommet. Want to make sure I have the right bit in advance, and I assume a spade bit works best drilling thru plastic?
I recommend the more sensitive K&N Filter Minder: K%N Filter Minder on Amazon
I had the Wix filter on my Toyota 5.7L V8 and it never registered.
The Wix filter gauge indicated 8-25 inches H2O and was not sensitive enough for my application.
The K&N filter gauge indicates 0-10 inches of H2O and shows a 50% (approx. 5 inches H2O) restriction after a WOT test with a new OEM paper filter.
Installation is easy:
Measure twice, cut once:
Use an 11/16" spade bit to cut the hole on the air box. I also used a small amount of K&N Air Filter Grease to assure a good seal to the grommet:
Voila!:
Close-up of the K&N Filter Minder:
You probably have all this sorted already, but if not, I hope you find this helpful.
