Originally Posted By: Donald
Find a NEW mechanic.
The only mystery about MMO is why people still use it.
Because it works,that's why they've been in business for 90 years.
Originally Posted By: Swissdieselfan
What exactly is supposed to be wrong with your engine and does it have a turbo charger??
Playing with oil additives is an act of last resort, most old engine related problems can be helped with a major brand high mileage oil and shorter OCI's.
The main risks of using drive around oil scorers:
1/ The oil filter or oil pump intake screen blocks.
2/ You dissolve the varnish helping an old oil seal function and start an oil leak.
3/ Debris from the sump obstructs the oil feed line to the turbo or damages the bearings (The oil thinning effect is only a longer term issue)
4/ Some of the solvents can degrade gas engine oil seals (Current warnings for GM and hyundai in particular)
Liqui moly who make a scourer in addition to their safer idle only flush, do include a specific warning about use for severe sludge cases:
One 300 ml can is sufficient for engines with oil capacities up to 5 litres of oil. After adding the product, drive as usual for about 100-300 km but avoiding full acceleration and then change the oil and oil filter.
In extreme cases of contamination, repeat the cleaning process and, if necessary, clean the oil screen in the oil sump. Oil-Sludge Scourer can be used before each oil change
Originally Posted By: andyd
Read the label on the bottle and know that if you follow the directions,the very worst thing is that no harm will come of it. I have used MMO for yrs in my small engines and such. It appears to have made them start easier and run smoother. I have used it in my car's gas and it made the car seem to run better. Even the wife commented on how well the car was running. No increase in MPG was noticed so I dont add it regularly. But I would use it if a car developed a carbon deposit trouble.
There are far better fuel additives available than MMO and most manufacturers have an approved or recommended one. If your engine doesn't have a turbo charger then flush additives are safer, although if you really can't be bothered or are unable to clean at least the sump and oil pump screen if you develop a sludge problem, then an idle only flush like that made by Amsoil or Castrol is far safer to use, although even idle flushes can start oil leaks.
Ahh yes. Skyshio and his turbo spiel again. How often do you need to be told this isn't Europe and turbo'd vehicles make up a very small percentage of all the vehicles on North American roads. So drop it.
Mmo doesn't cause leaks anymore than synthetic oil does,so drop the fear tactics.
You haven't used the product skyship so what can you even add to this thread. ABSOLUTELY NOTHING. AS USUAL.
Skyship,post in threads where you actually have experience. Like if someone asks why they had a turbo runaway. Or maybe that bus experiment. You got lots of info on that.
Skyship. I am going to follow you around and post right behind you. Get used to me,discrediting every junk post you write.
Op. ignore whoever this guy is today. I use mmo regularly,I've even got an intake mister that mists mmo into my intake so it has a steady feed of mmo at all times.
Dermapaint has been using the stuff for 40 years. If you want actual facts from a man with experience using it in countless applications then I suggest just messaging dermapaint directly. It will save you a headache reading a thread filled with posts where the poster has an agenda.
And I suggest ignoring swissdieselfan/Bodensee/skyship. If you look up his previous comments before being banned you'll see he all his posts say read the manual,use what they tell you,don't use additives blah blah blah.
Then he will write a bunch of lies like flush additives causing a turbo vehicle to runaway,and all kinds of absolute horsedung.
He is nothing but a troll. Treat him as such.
Mmo is great stuff. Use as directed. They have been in business for 90 years for a reason. And guys who use it seem to continue using it,so there must be some kind of benefit.
Pm dermapaint. He will give you the straight facts,considering he's used it for decades.
