Below is a voa of the oil BMW prescribes for all the naturally aspirated port injected M cars, Castrol Edge Professional TWS 10w60. The voa was done by Polaris. The oil is made in Europe; it is API SM ACEA A3/B3. The bottle bears a "Filling date 12.07.12". I am under the impression that TWS is, or was in the beginning, ester based. The 10w60 grade was first used by BMW in 2001 with the new e46 M3's. It came in bottles labelled Castrol RS 10w60. About a year after that, the 10w60 used in the M cars came in bottles labelled Castrol TWS 10w60. My particular application is in a 2013 M3 with 4.0 liter V8, 414 hp @ 8400 rpm.
aluminum 8
iron 1
silicon 7
titanium 47
moly 198
boron 59
calcium 2823
phosphorous 804
zinc 922
vis 100 C 20.7
base number 10.8
oxidation (abs/cm) 8
nitration (abs/cm) 4
Polaris flagged the viscosity as "moderately low". I've always considered the TWS as a heavy 50 wt (at 100 C). The vis is just a hair under the 60 wt line (21.9), so I'm not too concerned with the viscosity out of the bottle.
I've read that in voa's that labs can interpret esters in the oil as oxidation/nitration, so I'm a little surprised that the oxidation/nitration figures aren't higher - - if indeed, TWS is still ester based. Of course, there's a lot in a formulation that doesn't show up in a voa. Any comments appreciated.
aluminum 8
iron 1
silicon 7
titanium 47
moly 198
boron 59
calcium 2823
phosphorous 804
zinc 922
vis 100 C 20.7
base number 10.8
