Any sellers on amazon for Honda A02?
by BTLew81. 07/18/19 03:44 PM
First SMR (MMR) slated to be built at Chalk River
by OVERKILL. 07/18/19 03:31 PM
Torque Specs for 2004 Dodge Ram transfer case
by diyjake. 07/18/19 02:15 PM
OAT ad NOAT
by CCI. 07/18/19 02:06 PM
30 years clean & sober today.
by Papa Bear. 07/18/19 02:03 PM
What is high output AC?
by Fitz98. 07/18/19 12:45 PM
Killed my receiver
by Quattro Pete. 07/18/19 12:35 PM
I did it! Put Straight HD30 in the PSD...
by racin4ds. 07/18/19 12:34 PM
Bobcat S630 engine oil
by Spdfrk1990. 07/18/19 12:09 PM
737 max... what now?
by Tdog02. 07/18/19 11:46 AM
Picked up a Hyundai oil filter from WM
by mclasser. 07/18/19 11:29 AM
Mobil1 20w50 Vtwin in a tuff torq K61
by gman2304. 07/18/19 10:47 AM
4t outboard W rating question
by 1978elcamino. 07/18/19 10:27 AM
Top three based on known specs.
by sloinker. 07/18/19 10:24 AM
Harbor freight 25% coupon
by Fitter30. 07/18/19 10:11 AM
Going to try longer OCI.
by mctmatt. 07/18/19 10:06 AM
diagnosing a/c problem
by matrass. 07/18/19 09:49 AM
Shaz, Grousebeater, RoyD, clonis, golddots
68699 Registered Users
127 registered members (1978elcamino, ad244, Alfred_B, 32319, 1WildPig, Al, 12 invisible), 2,182 guests, and 21 spiders.
Topics292,035
Posts5,015,702
Members68,699
Most Online2,967
Mar 10th, 2019
09 wrx, Amsoil HDD 5w-30 #2952369
03/26/13 05:26 PM
03/26/13 05:26 PM
Ohio
WrxRcr Offline OP
WrxRcr  Offline OP
Ohio
Oil report
Ran over 15 autox events on this oil. Oil temps reached around 240 degrees on a couple weekends where ambient temp exceeded 100 degrees. I added 3/4 can of lubro-moly.
Seems like the oil thickened up some over its life.
Re: 09 wrx, Amsoil HDD 5w-30 [Re: WrxRcr] #2952380
03/26/13 05:46 PM
03/26/13 05:46 PM
MN
Turk Offline
Turk  Offline
MN
Please put the numbers in, that link don't work.
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
Re: 09 wrx, Amsoil HDD 5w-30 [Re: WrxRcr] #2952386
03/26/13 05:51 PM
03/26/13 05:51 PM
IL, USA
CMMeadAM Offline
CMMeadAM  Offline
IL, USA
Originally Posted By: WrxRcr
Oil report
Spec [email protected] is 11.7. Report shows 11.3.....how do you figure it "thickened up?"
Re: 09 wrx, Amsoil HDD 5w-30 [Re: WrxRcr] #2952393
03/26/13 05:54 PM
03/26/13 05:54 PM
ohio
randomhero439 Offline
ohio
Nice report for 15 events!
'03 Accord V6-6MT: M1EP 0w-20, daily
'10 Mercedes GLK: M1 0w-40, wife's car
'00 S2000: M1 0w-40, track car
'08 Corvette Z06: M1EP 5w-30, summer daily
Re: 09 wrx, Amsoil HDD 5w-30 [Re: WrxRcr] #2952399
03/26/13 06:04 PM
03/26/13 06:04 PM
Northern, NY
Rob_Roy Offline
Rob_Roy  Offline
Northern, NY
Looks like the oil did a fine job to me. Wear metals are higher than average, but the average probably doesn't include much track time. grin
Isn't this one of engines that had issues with the oil screen clogging that feeds the turbo? I believe in 2010 Subaru started mandating the use of synthetic oil in the turbo engines...but I have only recently started to read up on Subie engines.
My opinion...a premium synthetic oil can do a fine job on its own. Either let the AMSOIL go it alone, or source some oil that comes with moly already in the jug.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: 09 wrx, Amsoil HDD 5w-30 [Re: Rob_Roy] #2952424
03/26/13 06:32 PM
03/26/13 06:32 PM
Ohio
WrxRcr Offline OP
WrxRcr  Offline OP
Ohio
Yeah, i think next time i might leave the moly out.
Re: 09 wrx, Amsoil HDD 5w-30 [Re: CMMeadAM] #2952426
03/26/13 06:34 PM
03/26/13 06:34 PM
Ohio
WrxRcr Offline OP
WrxRcr  Offline OP
Ohio
[/quote] Spec [email protected] is 11.7. Report shows 11.3.....how do you figure it "thickened up?" [/quote]
The two viscosity numbers increased over the first report running same numbers.
Re: 09 wrx, Amsoil HDD 5w-30 [Re: WrxRcr] #2952467
03/26/13 07:21 PM
03/26/13 07:21 PM
Ohio
WrxRcr Offline OP
WrxRcr  Offline OP
Ohio
One additional thing, I started draining my oil when I remembered that I wanted to do and oil sample. I ran over to my tool bench open up the package from blackstone and then screwed off the lid. By the time i got back to my car the oil was drained. I manipulated the jack to get the last bit of oil out of the pan to fill the container with. Not sure how much of an affect this would have on the report. Oil was cold, car had been sitting for a couple days.
Re: 09 wrx, Amsoil HDD 5w-30 [Re: WrxRcr] #2952481
03/26/13 07:29 PM
03/26/13 07:29 PM
Saskatoon canada
Clevy Offline
Clevy  Offline
Saskatoon canada
I'm very curious to see a uoa with this many track events on the oil without the mos2. I will bet wear metals are much higher without the mos2 added.
Thanks for posting.
2006 Charger RT
Miles x 2 per oil filter
Re: 09 wrx, Amsoil HDD 5w-30 [Re: Clevy] #2952489
03/26/13 07:35 PM
03/26/13 07:35 PM
Ohio
WrxRcr Offline OP
WrxRcr  Offline OP
Ohio
Thanks for posting.
This last change i didnt add nearly as much moly, give me 6 months and i will have another report for ya.
Re: 09 wrx, Amsoil HDD 5w-30 [Re: WrxRcr] #2952965
03/27/13 09:47 AM
03/27/13 09:47 AM
IL, USA
CMMeadAM Offline
CMMeadAM  Offline
IL, USA
The two viscosity numbers increased over the first report running same numbers. [/quote]
In your first report, the oil sheared just over 8%. In the second, with 15 claimed autocross events, it sheared half of that, a little over 4%. Considering it's use, the HDD 5W30 performed quite well.
In addition, more than just a couple of UOA's over similar use would be more meaningful
to indicate any kind of trend.
As stated by othters, no additives to this oil are really necessary.
Re: 09 wrx, Amsoil HDD 5w-30 [Re: WrxRcr] #2954157
03/28/13 10:44 AM
03/28/13 10:44 AM
Ohio
WrxRcr Offline OP
WrxRcr  Offline OP
Ohio
The high silicon is probably leaching from when i installed a new killer b pick up tube prior to last fill.
