My Mazdaspeed3 is a consistent fuel diluter, at least the way I use it (4 mi commute). My last UOA showed 2.8% fuel and viscosities dropped out of grade (although TBN was still 5+). I'll have to disagree with those who claim the human senses can't read oil condition--this one reeks of gas as soon as you pull the dipstick. After 3000 miles, the oil is black and has lost lubricity. I used conventionals (mostly PYB) for the first 22,000 miles with good results. OCs were at 1250, 2500, then every 3,000. I switched to PP three changes ago. I changed the oil this weekend after 4000 miles because the oil looked, felt and smelled trashed. I've always used the recommended 5W-30.
Obviously, I could go up a grade and I've thought seriously about M1 0W-40. But, I don't like the increase in cold viscosity and it's a higher ash oil which I've been reading is not good for DI deposits. Is there another oil I should consider? I'm not really interested in the ultra expensive boutique oils. If anything, I'm considering going back to conventionals with 3000 mi OCIs.
Another thing feeding my concern is a notice received from Mazda where they extended warranty coverage on the turbo and timing chain but went out of their way to point out that this coverage would only be honored where oil changes did not exceed factory recommendations and that oil used must not be less than 30 wt. My 30 wt oils are quickly diluted to less than that so I'm concerned about it.
So is it just wishful thinking that any oil can help this situation or should I just accept the short intervals? Recommended grade or a step higher? If this, what about cold starts and my chronic short trips? Stick with syn or go back to conventional?
