Hi everyone, i'm looking to have some wives tales cleared up to either quash or confirm some reservations i have about using Delvac 1 ESP 5w-40 in my 2004 Subaru Forester 2.5L turbo with 70-80,000 miles
Im from Australia where we don't have any sub 0 degree celcuis weather - from alot of the reading on wrx/subaru forums - there has been overwhelming support for diesel oils to be used in our engines - support is also quite strong in America (on this forum) also for this oil
the main reasoning for this seems to be the robust nature of diesel oil (zero sheer loss) as well as the additives/detergent pack used
i myself have taken the plunge and serviced my foz with Mobil Delvac 1 ESP 5w-40 which is a group IV synthetic Diesel oil - i plan to drop this after 3000 kms (2000~ miles) as i have been advised that the first run with diesel oil will pick up a lot of soot/carbon due to the extra detergent pack
what i'd like to know is this;
- will the diesel oil be too potent for my engine - by means of cleansing out too much of the embedded carbon in my seals to cause leaks/blow by
- will this lead to the oil and petrol mixing and causing me grief down the track?
- will the diesel oil not serve my engine to its full potential because of various tolerances that a petrol motor has
- will/can diesel oil potentially posion my catalytic converter as i only have 1 now as opposed to the 2 cats given in the standard exhaust
I pose these questions/concerns as i've noticed slight blow by via white smoke from the exhaust which extended idling
i have also detected a difference in smell from the exhaust which smells like something dirty is mixing with the petrol - compared to my other car which gives out a pure smell of premium fuel
My other car is a Nissan Skyline R34 - and i've been using Motul 300V Chrono 10w-40
- will a 10w be find in the Forester?
there seems to be a taboo around the EJ boxer engines in australia and the variations in opinions are vast as to which is best
my goal is to best determine which is the very best oil for these engines to prolong the life/wear as much as i can - many tuners/enthausists here down under believe diesel oils are the way to go
i on the other hand think ester based oils are still the better suited option for subaru engines
sorry for the wall of text, i am pedantic (allbeit unqualified) and i am after the very best oil to use in my cars - the nature of my driving is on public roads with the odd occasion of spirited driving
i'm a first time subaru owner so i hope you forgive the silly questions - but as far as cars go there has never been a wider spectrum of opinions as to what is best
thanks again,
daniel
thanks again,
daniel
