If TBN is a measure of an oil's ability to neutralize acids, then why should the rate of depletion decline as the OCI progresses?
Put simply, if TBN has declined by, say, 80% in 4K miles, shouldn't it reach zero in another 1K?
I've sometimes posted in the UOA forum that oils with fairly low residual TBNs were not suited for longer drains, while others have replied that the oils would remain pretty stable at these low TBN levels for longer than a linear rate of depletion would indicate.
If this is so, then why?
