Forums Migration
Please read this thread
are all full synthetic high mileage oils similar?
by apollo18 - 07/13/20 09:50 AM
Does Ford put a 5 cyl. in an F150?
by JohnG - 07/13/20 09:06 AM
Rotella T4 15W40 Vs Mobil Delvac 1300 Super
by SR5 - 07/13/20 08:05 AM
OCI for Bobcat MT85, Kubota diesel
by NormanBuntz - 07/13/20 08:04 AM
sad times in the Super Tech filtration world.
by Jarpin - 07/13/20 08:03 AM
Fire on Bonhomme Richard...
by mattwithcats - 07/13/20 07:44 AM
pool deck paint
by CincyDavid - 07/13/20 06:32 AM
DIY Injector cleaning - What cleaner?
by Spetz - 07/13/20 12:50 AM
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
Revo, MuddyGeek, stepburns, JOLLY300, WheelHorseman
71923 Registered Users
113 registered members (Aichiguy, AlienBug, AdamZ, 94astro, 55hambone, 14 invisible), 2,079 guests, and 29 spiders.
Topics307,791
Posts5,317,888
Members71,923
Copper Strip Tarnish Test: 10 Gear & Trans Fluids #2554764 03/02/12 07:45 PM
P
pjf Offline OP
P
The Copper Strip Tarnish Test (ASTM D130-10) is a standard test of a lubricant to indicate how corrosive it is to copper alloys that may be in a transmission.
My restored 1989 Suzuki Sidekick has brass synchromesh transmission components that may be vulnerable to additives found in many GL5 lubricants. As a result, my owner's manual specifies a GL4 75W-90 or a GL4 80W-90 lubricant for the manual transmission and transfer case.
Lubricants that are "yellow metal friendly" are hard to find. I perused through data sheets and called lubricant manufacturers to find copper strip tarnish test results for their products. Those lubricants that I found test results for are in the table below.
Code:
M/T FLUID & GEAR OIL   SAE    API  CLASSIFICATION
Amsoil Long Life FGR  75W-90  GL5  1B Dark Orange
Amsoil Severe Gr SVG  75W-90  GL5  1B Dark Orange
Amsoil M/T Fluid MTF   5W-30       1A Light Orange
Amsoil MT & Gear MTG  75W-90  GL4  1B Dark Orange
Citgo Citgear Std XD  75W-90  GL4  1B Dark Orange
Delo Gear Lubric ESI  80W-90  GL5  2A Claret Red
Delo Trans Fluid ESI  50W          2A Claret Red
Red Line MT-90        75W-90  GL4  1A Light Orange
Red Line NS Gear Oil  75W-90  GL5  1B Dark Orange
Red Line 75W90 GL-5   75W-90  GL5  1B Dark Orange
A brief description of the test can be found here: description D-130. The classification scale ranges from 1A (least corrosive) to 4C (most corrosive).
Re: Copper Strip Tarnish Test: 10 Gear & Trans Fluids [Re: pjf] #2554776 03/02/12 08:01 PM
Colt45ws Offline
Wow, Im surprised Delo ESI is so hard on copper. Interesting.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Copper Strip Tarnish Test: 10 Gear & Trans Fluids [Re: pjf] #2554827 03/02/12 08:51 PM
J
JRed Offline
J
Why not research some more readily available GL-5 rated gear lubes such as the common Valvoline 75w-90 and 80w-90?
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Devourer of Oil
Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: JRed] #2555658 03/03/12 03:49 PM
P
pjf Offline OP
P
After posting the above table in a Suzuki forum, one of the moderators brought to my attention "A Study of Automotive Gear Lubes" on the Amsoil website (http://www.synthetic-oil-tech.com/Gear%20Lube%20White%20Paper.pdf).
On page 17 are ASTM D130 results for 14 gear lubes including Valvoline High Performance (80W-90) and Valvoline SynPower (75W-90). Both are classified as "1B."
I'm not sure how Amsoil got some of these results. I had called Pennzoil, Quaker State and Shell. Their support desks told me that they had no ASTM D130 information. I did not contact Valvoline.
We now have Copper Strip Tarnish Test results for 22 gear lubricants (10 + 14 - 2 overlap = 22).
Feel free to contribute by checking product data sheets or calling product technical support lines.
Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: Colt45ws] #2555708 03/03/12 04:28 PM
P
pjf Offline OP
P
I never got a clean answer from Chevron Tech Support on the amount of sulfur in its Delo ESI lubricants. This prompted me to send samples of the two Delo ESI lubricants to Wear Check, which provides sulfur & boron content in its elemental analysis.
Unfortunately, after 9 days the lab still has not received the samples from USPS. If someone has sulfur content analysis of the ESI lubricants, please post them before I order more sample kits.
Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: pjf] #2555899 03/03/12 07:14 PM
P
pjf Offline OP
P
Here's the updated list of 22 gear & transmission fluids that includes data from the Amsoil paper (www.synthetic-oil-tech.com/Gear%20Lube%20White%20Paper.pdf):
Code:
M/T FLUID & GEAR OIL  WEIGHT  API  CLASSIFICATION
Castrol Hypoy C       80W-90  GL5  1B Dark Orange
Castrol SYNTEC        75W-90  GL5  1B Dark Orange
GM Synthetic Axle     75W-90  GL5  1B Dark Orange
Lucas 75/90 Synthetic 75W-90  GL5  4B Graphite Blk
Mobil 1 Synthetic     75W-90  GL5  1B Dark Orange
Mopar Synthetic
w/Mopar LS additive   75W-90  GL5  4A Trans Black
Pennzoil Gearplus     80W-90  GL5  1B Dark Orange
Pennzoil Synthetic    75W-90  GL5  1B Dark Orange
Royal Purple Max-Gear 75W-90  GL5  4A Trans Black
Torco SGO Synthetic
w/Torco Type G LS add 75W-90  GL5  1B Dark Orange
Valvoline High Perf   80W-90  GL5  1B Dark Orange
Valvoline SynPower    75W-90  GL5  1B Dark Orange
Re: Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: pjf] #2556025 03/03/12 08:58 PM
MolaKule Offline
Global Moderator
Global Moderator
Note the ASTM D130 test coupons never showed any corrosion, only tarnishing, except for the Lucas, MOPAR LS additive and the RP. But most of those lubes are primarily differential lubricants, not manual transmission lubricants. And how many modern differentials use brass components?
Also notice the copper strip used for testing is pure copper, not the brass copper alloys used in transmissions. which are more resistant to corrosion.
Your brass synchros will wear out long before any of the sulfur corrosively attacks them.
You are forgetting the fact that gear lubes contain metal deactivators, rust inhibitors and TAN buffers to inhibit any copper alloy attack.
I have torn apart quite a few manual trannys and have never seen any tarninishing of the brass synchros, with one exception. This exception was a manual tranny from a farm truck with 180,000 miles on it and the fluid had never been changed.
Which leads me to my final point: Change fluids between 30,000 and 50,000 miles to replenish original base oil viscosity and additives.
I think you're making a mountain out of a molehill.
"So many shows out there dumb-down the country. It's so admirable to be part of a show that wants people to think." (David Krumholtz 'Charlie Epps' of NUMB3RS)
Re: Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: MolaKule] #2556125 03/03/12 10:30 PM
P
pjf Offline OP
P
...except for the Lucas, MOPAR LS additive and the RP.
Re: Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: pjf] #2761223 10/02/12 08:14 PM
P
pjf Offline OP
P
The previous link to "A Study of Automotive Gear Lubes" has failed. Here are alternative links:
http://www.smokinvette.com/corvette/articles/a-study-of-automotive-gear-lubes-part-1/
http://www.smokinvette.com/corvette/articles/a-study-of-automotive-gear-lubes-part-2/
The 2nd link contains the copper strip tarnish test.
Re: Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: pjf] #2804125 11/15/12 10:23 PM
N
Norm Olt Offline
N
So, with the exception of RL MT90 and AMSOIL MTF (rated 1A and both GL4) any of the other brands rated 1B should be A-OK for a manual transmission?
i.e., RL's NS Gear Oil and their 70W-90 GL5 s/b OK as well?
Thanks!
17Outback 17K
01ValkyrieIS 6K
93ZX11D 30K
87F250 185K
88420SEL 178K
88420SEL 212K (parts)
91420SEL 235K
92SVX 186K
00Nighthawk250 1.5K
93SC400 105K
92SC400 75K(!)
Re: Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: MolaKule] #2908886 02/16/13 08:26 PM
P
pjf Offline OP
P
Yes, a 1A or a 1B rating indicates a "yellow-metal friendly" transmission oil. An oil can be trusted to be "yellow-metal friendly" if it adheres to GL-4 standards. On the other hand, a GL-5 oil has to be tested to ensure that it passes the ASTM D-130 copper corrosion test if you want to use it in an older transmission.
Of the 14 GL-5 gear oils in this study (http://www.goodsenseoil.com/G2457-GearOilWhitePaper.pdf), 3 failed the copper corrosion test. This means that the failure rate was 21% for this series of GL-5 oils.
Most car owners ignore the type of oil that mechanics place in their vehicles. You are in this forum because you care about the oil that you place in your transmission. If you have a classic car with yellow metals, do make it a point to use either a GL-4 oil or a GL-5 oil that passes the copper corrosion test.
Re: Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: pjf] #4049005 03/25/16 09:47 PM
R
revvedup Offline
R
I agree with MolaKule that this is largely a case of making a mountain out of a mole hill. Consider that some Military Spec I ran across lists not only 1a and 1b but also 2a as "copper friendly." Where does pjf come up with Chevron Gear ESI as being bad for yellow metal when the Chevron product that rates 2a is just one category (of 12) on the ASTM D-130 away from 1b which he refers to as safe for yellow metals?
The Military is interested in this stuff (ATSM D-130) because they have equipment sitting around sometimes for decades. The real shocker of this AMSOIL survey (merely a marketing scheme) is the Royal Purple product that rates 4a. Shocking really for a product that claims it is "yellow metal friendly." 4a is 3rd from the worst possible. For those interested in facts and clarity, it appears the ASTM D-130 has the following classifications for copper corrosivity. From best to worst--
1a. 1b. 2a. 2b. 2c. 2d. 2e. 3a. 3b. 4a. 4b. 4c.
Re: Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: pjf] #4049127 03/26/16 04:16 AM
Z
zeng Offline
Z
+1
Great guide.
Re: Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: pjf] #4051233 03/28/16 05:56 PM
Y
yvon_la Offline
Y
Allison automatic for big truck . my suggestion : Mobil delvac1
Atf (the one allison authorize.its the most awsome yellow metal friendly oil period(any oil allison ATF authorize is awsome
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
Re: Copper Strip Tarnish Test: 22 Gear & Trans Fluids [Re: pjf] #4068937 04/14/16 10:00 PM
R
Rand Offline
R
I wish that "goodsenseoil"
wasnt posted so much it could also be called.
"that amsoil marketing pdf"
But if we grant it "fact" status it can be an interesting read.
