Please explain beta ratios. I'm lost.
by tony1679 - 10/16/19 12:45 AM
Is sump pumps necessary?
by joy786 - 10/16/19 12:18 AM
Sensen Struts - Any Good?
by Nick1994 - 10/15/19 11:54 PM
Quiet Oil--Cause?
by jimbrewer - 10/15/19 11:05 PM
IFJF (Chinese Magnefine)
by mcwilly - 10/15/19 10:40 PM
Let the truck warm up?
by Dragon44 - 10/15/19 10:14 PM
6.4L Powerstroke under the knife
by clinebarger - 10/15/19 10:01 PM
Alternatives to SAE 90 gear oil?
by qwerty11 - 10/15/19 09:34 PM
2010 Infiniti G37x Feedback?
by maverickfhs - 10/15/19 09:30 PM
M1 0W20 High Mil 40C visc
by Silver - 10/15/19 09:14 PM
Havoline 6 Qt Box $11.99 / Free Shipping
by Mr_Luke - 10/15/19 09:02 PM
Oil Recommendation for LS7 Z06 Street & Track Usage
by randomhero439 - 10/15/19 08:46 PM
QSUD 0W20 in 5qt jugs
by faltic - 10/15/19 08:41 PM
Mission Impossible: The Giraffe
by MONKEYMAN - 10/15/19 08:20 PM
Alternative to 10w-40 in Rotella?
by qwerty11 - 10/15/19 08:18 PM
Oil Changes and Ramps
by perfect_oil - 10/15/19 07:50 PM
Where to use T4 15W-40 in a 10W-30 World?
by Astro_Guy - 10/15/19 07:37 PM
How Does Toyota Do It?
by lovcom - 10/15/19 07:29 PM
ARedStart, viper74656, Tar, cast71, bamadog1
69573 Registered Users
48 registered members (Bjornviken, Bailes1992, 4WD, 2002 Maxima SE, billt460, 8 invisible), 893 guests, and 19 spiders.
Topics296,027
Posts5,089,581
Members69,573
Most Online3,532
Jul 30th, 2019
GREASE FOR WARN WINCH #2452921 12/04/11 04:09 PM
splitpost Offline OP
Hey Fellas ,in the process of rebuilding my Warn winch ,now the manual calls for Aeroshell 17 to be used ,is there another brand grease that can be used ,Can't find a cross-ref chart with Aeroshell 17 in it,any help much appreciated
Re: GREASE FOR WARN WINCH [Re: splitpost] #2452985 12/04/11 04:57 PM
tom slick Offline
If it helps, from a TDS:
AeroShell Grease 17 is extreme pressure multipurpose grease recommended for heavily loaded sliding steel surfaces where protection against seizure and corrosion is desired; e.g. bogie pivot pins on jet aircraft landing gear assemblies.
It is made with synthetic diester base oil, molybdenum disulfide and Microgel non-melting inorganic thickener, which provides outstanding anti-friction bearing lubrication.
It has a useful temperature range of -100 F (-73 C) to +300 F (+149 C). AeroShell Grease 17 is qualified under MIL-G-21164D specification.
Seems to be a lithium complex with 5% moly.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: GREASE FOR WARN WINCH [Re: splitpost] #2453077 12/04/11 06:46 PM
Pablo Offline
You could substitute with this:
Amsoil Off Road #2 Grease
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: GREASE FOR WARN WINCH [Re: splitpost] #2453449 12/05/11 02:30 AM
Thanks fellas
Re: GREASE FOR WARN WINCH [Re: splitpost] #2475508 12/28/11 05:03 PM
T
tdi-rick Offline
T
Hey mate,
Aeroshell is a di-ester based grease, and I think uses a modified clay based thickener, it's definitely not lithium based.
I think it's discontinued now, (replaced with Aeroshell 33MS ??) and FWIW I'd use CAT Desert Gold grease instead.
You can get it from Westrac.
This is a synthetic oil (PAO) based grease with 5% moly and is calcium sulphonate thickened, so resists rust and water washout extremely well.
Land Rover.
Helping put oil back in the ground for 60 years.
You can't get any greener than that......
Re: GREASE FOR WARN WINCH [Re: tdi-rick] #2475794 12/28/11 10:16 PM
Thanks Rick smile
