First UOA on my boat. A 2001 Bryant with Mercruiser 4.3L V6 Vortec with throttle body injection. Total hours on boat is 145. Hours on oil is 53. Duration in crankcase Nov 2003 to July 2004. No makeup oil. Mercruiser oil filter -- a Champion. In use April 2004 to July 2004. ANA Laboratories did the report. Replaced with Amsoil 15W40 Diesel/Marine.
Please see: http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=11;t=000199
for the VOA on this oil.
Sb Titanium Silver Copper 11
Lead 14
Tin 1
Aluminum 3
Nickel Iron 19
Chromium 2
Cd Sodium 4
Boron 129
Silicon 115
Water Soot 0.0
Glycol N
Fuel 6.80
TBN 6.20
Vis @ 100 C Cst. 10.69
Moly 9
Mag 1023
Calcium 431
Barium 15
Phosphorus 1634
Zinc 1781
Lab comments:
Wear Metals - Normal
Lub Contaminants Silicon - Excessive [Critical]
Fuel Dilution, check for leaking injectors - Excessive [Critical]
Drain oil if not drained.
Change filter if not changed.
My comments: I can understand the high silicon -- boats run with flame arrestors which are just metal plates, basically w/o any air filtration at all. I am going to replace stock flame arrestor with K&N Coast Guard approved flame arrestor that provides filtration and higher flow.
I don't understand the fuel dilution. This thing has a glorified carb -- an EFI that is throttle body injection. The only thing I can guess is that we are always starting and stopping the thing during water sports. When you turn on the ignition, the injectors spray fuel in the intake for starting. Perhaps it is not all getting burned. Fuel consumption is not excessive -- very normal.
Perhaps I should change the oil every 20 hours with cheap Delo.
Certainly not thrilled that the oil thinned to 10.69 -- is that because of the fuel dilution?
One thing I know for sure is that I won't be using this oil again.
Please comment!
Lead 14
Tin 1
Aluminum 3
Nickel Iron 19
Chromium 2
Cd Sodium 4
Boron 129
Silicon 115
Water Soot 0.0
Glycol N
Fuel 6.80
TBN 6.20
Moly 9
Mag 1023
Calcium 431
Barium 15
Phosphorus 1634
Zinc 1781
Lab comments:
Please comment!
