Mobil 1 0W40, 7721 miles, 2002 Volvo V70 T5
Astro14
$100 Site Donor
Staff member
Virginia Beach
Attached is the UOA for a 7 month, 7721 mile run on M1 0W40 in my 2002 Volvo. Mahle filter.
I am relatively pleased with the results, though I can't explain the slight fuel contamination, except that there were a lot of errands/traffic before taking the sample, and perhaps the extensive idling was causal. I noticed no M1 "issues" like high Fe. I don't have a VOA, so I can't tell if it has sheared significantly from new but 11.9 CsT is right where a heavy 30 (like GC) or a light 40 would be and is appropriate to this car.
I plan to keep using it.
Html:
Volvo 2.3 L Turbo
Gasoline (unleaded)
Mobil 1 0W40
7,721 Miles on Oil
120,045 Miles on vehicle
Wear in this 2.3L looks good after more than 7,700 miles on the oil.
Metals read at or better than universal averages, which are based on 5,600 miles.
We did see fuel at 0.5%, but this level isn't typically enough to pose an issue.
The TBN was fine at 2.7, showing some active additive left. A TBN of
less than 1.0 is too low for extended oil use.
Overall this engine looks good at just over 120,000 miles.
Try going 9,000 miles next time.
Universal Averages
ALUMINUM 2 4
CHROMIUM 0 0
IRON 7 15
COPPER 5 5
LEAD 0 2
TIN 0 1
MOLYBDENUM 57 86
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 1 2
BORON 73 54
SILICON 4 7
SODIUM 3 17
CALCIUM 2534 2309
MAGNESIUM 134 143
PHOSPHORUS 880 775
ZINC 859 928
BARIUM 0
Should be
cSt Viscosity @ 100°C 66.1 65-76
SUS Viscosity @ 210°F 11.90 11.6-14.8
Flashpoint in °F 365* >375
Fuel % 0.5
Antifreeze % 0 0
Water % 0
Insolubles % 0.2
TBN 2.7
Great UOA!!! Another great M1 0w40 report. Not much else to say
Looks good. I'd cut the oci back to 6 months and cut the UOA's out. Just go to a Fall and Spring Oci regimen,that's what I do.
Originally Posted By: db500
Nice report...did you add any makeup oil?
I did - 1 quart.
