Castrol 0W-20?
by TRDPRO85 - 02/19/20 02:44 AM
What is a dealer prep fee?
by WhyMe - 02/19/20 01:01 AM
Vintage Sinclair promo
by HiPowerShooter - 02/18/20 11:29 PM
why did my Ford iolm go to 9% after 3k miles?
by dogememe - 02/18/20 11:15 PM
HUBB reusable stainless steel filter?
by Vern_in_IL - 02/18/20 08:41 PM
Ultrasonic carb cleaning problems
by atikovi - 02/18/20 08:05 PM
Cheeseburger pie
by P10crew - 02/18/20 07:25 PM
The midwinter detail.
by dan_erickson - 02/18/20 05:27 PM
Tired of Using Cassette Player with iPhone
by Gebo - 02/18/20 05:04 PM
STP oil filter
by Stinky123 - 02/18/20 04:41 PM
How is this possible
by V10 - 02/18/20 04:07 PM
Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
GardenStateAudi, Strommen95, Idaholewis, Sprite, spbonus
70746 Registered Users
25 registered members (cjolson140, Char Baby, Bailes1992, bbhero, cjcride, boostedtsiawd, 1 invisible), 949 guests, and 18 spiders.
Topics301,634
Posts5,199,572
Members70,746
Bars leaks #2263435 05/17/11 07:52 AM
B
brick Offline OP
B
Bars leaks has several additives. Powder,Pellets and i saw a liquid mix,didn't say or see pellets in it.
Which is better or a preferred one?
Impala 3.4 (3400) and i'm going to get a coolant flush and want to add what people say is the TABS,can't locate the tabs so having used bars in the past with the pellets is that good enough for added protection?
I lOVE this website! TONS of information.
Ppl say use 2 tabs but can't find that tabs yet.
Shakin' the tree boss...shakin' the tree ! (cool hand luke)
Re: Bars leaks [Re: brick] #2263439 05/17/11 07:58 AM
P
pbm Offline
P
From what I understand the powder is really just crushed tabs.
All Barsleaks products which claim to stop leaks (tabs, powder, pellets) work on the same principle and should work as intended.
I assume you are using this product as a PM for a leaky I/M gasket problem? I did that with my 3.1 Buick until approx. 80K when I had the IMG replaced with a FelPro PS gasket.
In my experience the tabs, powder and pellets all work but they can plug up your heater core if overused.
'Journalism is Dead'
Re: Bars leaks [Re: brick] #2263440 05/17/11 07:58 AM
H
Honda_Jim Offline
H
Autozone can get the tabs. Some carry in store also. Tabs are DIFFERENT than powder and pellets, so find the tabs.
Re: Bars leaks [Re: brick] #2263449 05/17/11 08:09 AM
P
PhillyJoe Offline
P
Your GM dealer should also have the tabs. Pretty sure I read here that Bars Leaks makes the tabs for GM.
Re: Bars leaks [Re: brick] #2263483 05/17/11 08:49 AM
F
FL_Rob Offline
F
I have used the the Bars Leak liquid copper stuff(block gaskets,rad,hoses) and the liquid silver(rad only)also the powder .In my experience,the liquid copper is the best I've ever used.The the particles are already in suspension and very fine so no heater core clogs but it does take at least one full bottle to work,depending on the leak.I tried to 'spoon feed' it for fear of clogs ...nope,just put the whole container in.
Re: Bars leaks [Re: PhillyJoe] #2264168 05/17/11 08:17 PM
cronk Offline
Bars does make the stop leak tabs for GM.
You should be able to get them at any GM dealership, they are reasonably priced, last time I bought some.
In my opinion, they are about the most safe and effective stop leak additive.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Bars leaks [Re: brick] #2265007 05/18/11 04:57 PM
Stu_Rock Offline
I agree that Bars Leaks (or GM rebranded) tablets are the way to go. I use it as a preventative measure in my two older vehicles.
I think one of the Bars Leaks powders has the same formula, but most of them do not. The ingredients are ginger, almond shell, turmeric, and sodium carbonate.
Also, don't put too much in. Most GM engines seem to call for one tablet for each gallon of coolant mix. That's probably two tablets for a 3400 W-car. Three might be OK, but disregard the packaging's instructions to use all six!
Re: Bars leaks [Re: brick] #2265351 05/19/11 12:06 AM
B
brick Offline OP
B
THANKS!! Looking for added protection in case something might happen. I've read on this site that the 3400 v/6 i have in my 2005 impala (35,500 miles) is not a problem motor for intake leaks,it was the years before that so i've read on here.
Be that as it may..i'd like some added protection,ya never know.
I have not had a leak since the start of the past winter and that leak was only about 1 qt or less but it did have air in the system,i could hear it.
The oil has aways been clean,no issues with that and i check it alot to be sure and i get's changed very regular.
Guess i'd like to try to stay one step ahead in the game.
Autozone here did not have nor know about the tabs,just had powder and liquid forms.
Will try the local gm guy or napa.
Re: Bars leaks [Re: brick] #2265356 05/19/11 12:18 AM
A
asiancivicmaniac Offline
A
Probably best to not fix what isn't broken in this case.
2002 Nissan Maxima: Napa Syn 5W-30, Proline 14459
2020 Honda Civic Si: Factory Fill, OEM filter
Re: Bars leaks [Re: brick] #2852836 12/30/12 05:58 PM
Y
yonyon Offline
Y
There was a time when GM needed this stuff to control coolant leaking through cast aluminum parts and started using it.
In time, Mazda and then Nissan needed it but didn't use it. Gm (mostly) fixed their problems and (again mostly) stopped using the stuff. Now it's Ford that needs it and also doesn't use it.
The rabbit pellets work. They stop coolant from leaking through flawed aluminum castings. Too much makes a nasty mess and functions as the equivalent of oil sludge in the cooling system, but in small doses it's an effective way to prevent leaks. The biggest problem with them is that "use as directed" means use way more than is appropriate for PM. IMO the package recommends using an amount suitable for use with a small head gasket leak. Yes, the pellets can stop a minor head gasket leak.
Re: Bars leaks [Re: brick] #2854053 12/31/12 06:36 PM
crazy8 Offline
AC Delco part number 10-108 cooling system seal tabs.
Re: Bars leaks [Re: brick] #2854060 12/31/12 06:45 PM
T
Texan4Life Offline
T
my old 90 deville called for he GM tabs... I used 1 tube of the powder bars leak from walmart. worked fine.
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
Re: Bars leaks [Re: Texan4Life] #2854375 01/01/13 07:40 AM
T
Trav Offline
T
For sure it did its the same product.
Bars Leak Gold is the same as the Tabs and the GM tabs only in a powder form.
All three are Ginger Root based, the tabs just being compressed and more difficult to use (must be placed in the lower hose).
Ginger Root is preferred over metallic types because it remains in a shrunken state when wet and will only expand when exposed to air. For this reason it will not plug the heater or radiator.
It is the most effective type of safe sealer. Subaru uses this same formula in liquid form from Holts and works just as well as the tabs or the powder, it can be had at any Subaru dealer.
