My 2008 Audi A6 3.1L (3.2) FSI Quattro is experience on-going excessive carbon buildup on the intake valves (slightly different story than most posts)
Oil change interval is every 5,000 miles - not every 10,000 as manual states.
Driving habit - 600 miles per week, average speed 70-90 mph in North East.
Summary of events:
* While using Castrol Syntec 5w-40 oil
-- with Exxon 93 octane fuel, miss-firing begins every 1,000 miles after valve cleaning and requires valve cleaning approximately every 4,500 miles due to violent shaking and permanent CEL.
-- with Shell 93 octane fuel, miss-firing begins every 1,000 miles after valve cleaning and requires valve cleaning approximately every 4,500 miles due to violent shaking and permanent CEL.
(Chevron Tektron does not really help when used every 3,000 miles)
* While using Mobil 1 0w-40 oil
-- with Exxon 93 octane fuel, miss-firing begins every 4,000 miles and requires valve cleaning approximately every 7,000 miles due to violent shaking and permanent CEL.
-- with Shell 93 octane fuel, miss-firing begins every 4,000 miles and requires valve cleaning approximately every 7,000 miles due to violent shaking and permanent CEL.
-- with Sunoco 93 octane fuel, automobile requires a manual valve cleaning at 10,000 miles. The automobile does misfire, but the event is so minor, it is a non-issue. However, I have noticed decreased fuel efficiency since the move from Exxon and Shell and when I hit 12,000 miles (oil change interval is 5,000 miles), the miss-firing becomes the most violent, as if the engine will drop on the street.
* While using Mobil 1 5w-40 ESP M oil
-- experienced similar results to Castrol Syntec. I thought perhaps the low ash count would help.
My question is, what is your recommendation in my situation and what oil should I use to help mitigate the issue since it does have an impact?
My next trial and error is Mobil 1 5w-30 ESP, but is their something I should try first? My goal is to see if the miss-firing can hold off until 15,000 valve cleaning intervals, not less than 10,000.
Summary of events:
