brake caliper/ pad lube
by bonjo
05/24/17 01:49 AM
Quiet down an old engine?
by bennylava
05/24/17 01:29 AM
Anyone headed to Sturgis this year?
by montero1
05/24/17 12:57 AM
Utilities costs....
by gregk24
05/23/17 10:58 PM
Fram PH3786 vs Motorcraft FL-1995
by jongies3
05/23/17 10:55 PM
Bulk O rings
by bowlofturtle
05/23/17 10:52 PM
Real news?
by buck91
05/23/17 10:47 PM
Honing and i.d.
by buck91
05/23/17 10:42 PM
What oil filters for customers cars?
by Chris142
05/23/17 10:30 PM
Chevy Brake pedal relearn/reset.
by bowlofturtle
05/23/17 10:30 PM
What happened to the Purolator post?
by chainblu
05/23/17 09:34 PM
Mileage Dropped with PUP vs Mobil-1
by JerryBob
05/23/17 09:20 PM
Set of new tires for $47 at DTD sale
by faramir9
05/23/17 08:58 PM
Smaller favorite company oil
by bbhero
05/23/17 08:35 PM
Amsoil SS 5w-20, 56,000 miles, '11 Ford Expedition
by Crusher
05/23/17 08:28 PM
Widows Essentials
by Eddie
05/23/17 08:22 PM
Bio-Diesel in az?
by Chris142
05/23/17 07:52 PM
Undercoating mower deck
by Camprunner
05/23/17 07:42 PM
Borane additives for more zip?
by L_Sludger
05/23/17 07:31 PM
What is wrong with finished fuels?
by drfuelinstein
05/23/17 07:22 PM
sebin, TRMoore, dabo72, djscotty14, 4501_Safari
61649 Registered Users
19 registered (farrarfan1, FordBroncoVWJeta, bbhero, Ducked, 3 invisible), 1078 Guests and 9 Spiders online.
61649 Members
66 Forums
265535 Topics
#211548 - 12/03/04 06:57 AM Impact wrench lube
phenomic Offline
Loc: MI
I just got an impact wrench and i thought you were supposed to lubricate them. It didnt come with any oil and im not sure where you put it. Instructions dont mention it.
Do i need to do anything to it or not and if so where do i put the lube and what kind should i use?
#211549 - 12/03/04 07:19 AM Re: Impact wrench lube
Pablo Offline
Loc: Duvall WA - Pacific NW USA
No instructions on lubing it? Strange. Is it a cheapie? If there is no lube port, the just put the lube in the opening for the air. Turn it by hand and add some more....
I like the PBBlaster brand of Air Tool Lube the best. I've used the Sentrol stuff and even synthetic ATF with no issues (but I supposed ATF may not be a bright idea, my tools have lots of time on them)
I've heard not to use WD-40, but frankly I wasn't tempted. I do use WD-40 for cleaning stuff, but not as a serious lubricant.
#211550 - 12/03/04 07:24 AM Re: Impact wrench lube
kenw Offline
Loc: Houston
when i worked in the factory, the air tools had inline oilers, feeding oil thru the air intake. Part of a "trio", a combo filter, dryer and oiler for each workstation.
#211551 - 12/03/04 07:24 AM Re: Impact wrench lube
Marlin Offline
Loc: Raleigh, NC
WD40 is not a great lube, don;t use it on air tools.
As for your gun, put the oil where the air hose attachs. There is a thin grease that goes in the side of the gun, might be a hex screw to remove to add.
I have used Mobil1 Syn Gear oil as well as the cheap stuff just fine.
#211552 - 12/03/04 07:34 AM Re: Impact wrench lube
Chris142 Offline
Loc: apple valley, ca
Your local auto parts store as well as Walmart have air tool oil.
#211553 - 12/03/04 07:52 AM Re: Impact wrench lube
phenomic Offline
Loc: MI
Its an older craftsman model that didnt sell at its original 200$ so i got it for 40. I think its a good one. I havent messed with it much. So motor oil will work and how often should i do it?
#211554 - 12/03/04 07:58 AM Re: Impact wrench lube
Pablo Offline
Actually I don't think motor oil is a very good idea. You want a lube with very low/no ash and motor oil maybe a bit to high viscosity. ATF will work as I mentioned, but use a synthetic one, like M1. Or just buy the Walmart air tool lube as mentioned.
#211555 - 12/04/04 07:41 AM Re: Impact wrench lube
Neil Womack Offline
Loc: Central Texas
I've used ATF (what ever is already open in the oil locker) for some time with no issues.
#211556 - 12/04/04 10:55 AM Re: Impact wrench lube
phenomic Offline
Loc: MI
Thanks for the help, i found the instructions and it said to use an inline filter and keep it oiled with air tool oil. Ill see what i can get ahold of, thanks.
#211557 - 12/04/04 07:33 PM Re: Impact wrench lube
GarrettSocling Offline
Loc: Jersey Shore, PA
so the oil that goes in the air port and the grease that goes in the side through the hex stopper are two different lubricants?
#211558 - 12/05/04 03:16 AM Re: Impact wrench lube
kenw Offline
Loc: Houston
quote:
yes. The oil in the air lubes the motor. The grease on the gears lubes, well... the gears; these are (evidently) in this particular tool not in the airstream.
Many tools (the ones in my experience at least) used the same oil; as all parts were all in the airstream and therefore the "oilstream". I can see that many tools, especially heavier ones would have separate sections, hence separate lubes.
#211559 - 12/05/04 05:21 AM Re: Impact wrench lube
brian fix Offline
Loc: wisconsin
I know this sounds strange,but some mechs I know use Mobil-1,5w30 thined slightly with Marvil mystery oil? they get long lived use out of the tools used....infact very good........ BL
#211560 - 12/05/04 06:55 AM Re: Impact wrench lube
dkcase Offline
Loc: Suburban St. Louis
I have used Marvel Mystery Oil and also Kroil. I tried the Kroil I think because of reports they published in their literature.
Now, I broke down and picked up a small bottle of Campbell-Hausfeld branded "air tool oil." I got it either at Autozone, WalMart, or Sears Hardware.
As much as I use, it will last a long time for me.
#211561 - 12/12/04 05:19 AM Re: Impact wrench lube
Ray B Offline
Loc: N.W. Indiana
Checked the lubing directions on a cheap 1/2" impact and a good quality 1/2" impact. Both have a small hex screw on the side to add 30 wt. oil to the clutch.About 2/3 oz. checked monthly. You also need to add a 10 wt. oil( like Mobil Almo 525 air tool oil) to the air inlet on the tool every time you use it. About 2 drops if you do not have an auto oiler setup.And a couple of drops when you are done.
Ray
