Dewalt DXCM251 25-Gal Oiled Air Compressor
by The Critic - 04/06/20 03:40 AM
Windows File & Folder Fix Tool
by ZeeOSix - 04/06/20 01:53 AM
$.25 washer fluid at WM
by joel95ex - 04/06/20 12:13 AM
`16 Suburban OLM never tripped due to time
by zfasts03 - 04/05/20 11:26 PM
Straight 30W [Briggs & Stratton] @ Amazon
by SlavaB - 04/05/20 10:56 PM
Bosch 3323 Premium Filter Cut Open
by TrainingPolicy - 04/05/20 10:29 PM
CARQUEST Premium Oil filter 84341 Cut Open
by TrainingPolicy - 04/05/20 10:12 PM
C-1706 SAKURA Cut Open
by QuangTeo - 04/05/20 10:07 PM
Had to smile
by AZjeff - 04/05/20 10:04 PM
Childhood friend dies
by Marco620 - 04/05/20 10:00 PM
Leftover 100LL in vehicle
by PantherFan88 - 04/05/20 09:42 PM
The good old days.:)
by A310 - 04/05/20 09:04 PM
Harvest king switched suppliers confirmed.
by Micahmcmeen - 04/05/20 08:15 PM
Mobile 1 Synthetic 15w/50 - Not what it used to be?
by NorCalHD - 04/05/20 06:21 PM
Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
F7daved, khouan, daniell, carguy1701, London
71106 Registered Users
17 registered members (bbhero, iontrap, CB900F2, JohnnyJohnson, Gokhan, Bailes1992, 1 invisible), 1,198 guests, and 13 spiders.
Topics303,659
Posts5,239,317
Members71,106
Promotive is the same as Purolator? #2049085 10/17/10 12:04 AM
R
Rockford Fosgate Fan Offline OP
R
Just trying to confirm something. I know a shop that sells Promotive filters and the techs told me they are the same as Purolator filters...is this true?
Re: Promotive is the same as Purolator? [Re: Rockford Fosgate Fan] #2049094 10/17/10 12:14 AM
chubbs1 Offline
I can't tell you they are the SAME as Purolators but they ARE made by Purolator. If that makes sense. ie. Champion makes a lot of filters but they vary in quality.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
Re: Promotive is the same as Purolator? [Re: chubbs1] #2049195 10/17/10 06:13 AM
Sayjac Offline
+1 But, I'll say no, they are not the same. More likely, less media, perhaps smaller in size, and not as efficient. Many folks say fill in the blank made by Purolator, is the same as the Classic(usually), likely because it sounds good. However, those filters are made by Puro to the specs of the vendor, eg., Pennzoil, Quaker State, Motorcraft etc.
In the case of the ProMotive it's what Advance now uses/sells for their commercial accounts. It takes the place of the PowerFlo, also made by Purolator, as well as the Advance Total Grip which were put in the back and closed out with the commercial accounts. The one difference I have noticed is, unlike the AAP Total Grip, with the ProMotive they have consolidated some of the application and generally use the smaller filter of those applications. Example, in the 14610/7317 application size, the available application is the 14612, which is smaller/shorter but still fits.
But, rather than me telling you, you can see it for yourself thanks once again to river_rat. http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1883207 HTH
Re: Promotive is the same as Purolator? [Re: Rockford Fosgate Fan] #2051653 10/19/10 03:46 PM
R
R
Thanks for the posts. I ended up going with Toyota OEM filters which were cheaper too.
