This is from a 2005 Ford Freestyle, AWD. The driveline is essentially same on the Volvo V/S70, XC70 (maybe 90?). 90K on fluid
Ouch...
I don't actually know what fluid was in there originally. Ford now specifies a full synthetic, this one here: http://www.fcsdchemicalsandlubricants.co...ansaxle%20Fluid
Interesting, since they also have a 75W90 GL-5 gear oil?
However, it specifies this over 75W90 GL-5 specifically for this car's PTU?
My FSM simply specifies GL-5 80W90, and doesn't say it's synthetic. Anyway, I drained out almost all of it and replaced w/M1 LS75W90. Since there was a tiny bit in there--and since I had the wrong size crush washer and had to re-use the old one, I'm going to drive for a bit to clean things up, then drain and fill with the Motorcraft PTU fluid. Unless people tell me that's a total waste of time. It holds 11 oz. and I got out around 9 oz.
The pic doesn't really do justice to how nasty this stuff looked on its way out. I have it sitting around, and it's looking pretty used. That said, there are no metal shavings, and it didn't smell burnt. This has given me new motivation to find that @$%$^#$* fill bolt for the rear differential (also filled with "lifetime fluid").
Who's lifetime are they talking about, anyway??
Ouch...
