Trans is GM TH400 in a ton truck. I just added an external filter and temp guage at my last oil change and flipped the $&*@ out. Normal temp is around 220 and pushed 235 with a small load on the back the other day. Installed a large cooler yesterday with only marginal results. 190 degrees on my way to work this morning and 220 again on my way home with an 800lb bale of hay this afternoon. I do a lot of heavy towing with this vehicle, up to 10,000 lbs. Can't wait to see what it does then. Anyway, the fluid I drained when changing had 17,000 mile on it and showed little to no degradation. Runs fine and shifts fine. Should I be worried?
